Diesel system purge
- Duke
- Vehicle: 92 Delica Super Exceed
Re: Diesel system purge
Geeeezz, now I click on afteroil's link.... duhhh.
Lubro Moly Diesel Purge is the stuff I used to use on the benz (I couldn't remember the name of it, but seeing the picture of the can and I definitely recognize it)
Worked wonders, but I can never find that sort of thing in the stores, they only ever seem to have the fuel additive stuff, which is not the same beast at all.
I can tell you that there was always a noticeable difference after using it on the mercedes.
- Profister
Now we are talking! Thanks guys, I found it: http://vancouver.en.craigslist.ca/pts/1108689114.html
- snelson
- Vehicle: 92 Delica Exceed
Could you post some pics when you run this stuff through - which lines to use etc..wouldn't mind trying it out as well.
That's the stuff I used on my old mazda diesel.Duke wrote:Lubro Moly Diesel Purge
Works great for a good hot chilly cleaning.
You don't have to go out to Maple Ridge to pick it up. Just go to a Napa. They carry it.Profister wrote:Now we are talking! Thanks guys, I found it: http://vancouver.en.craigslist.ca/pts/1108689114.html
- after oil
i emailed the guy but never heard back. my napa doesnt carry it, guess il ask next time im in there
- Profister
Napa in Langley quoted me $13.25/bottle. I do not need to go to Maple Ridge; the friend of mine living there will take care of this. The seller is slow negotiating the deal but hopefully next week it will be done. I am buying all 6 cans so I can share 4 of them.my napa doesnt carry it,
- delicat
Sergiy,
Now you only have 3 to deal with, I'll take the other one...thx
- Vehicle: Super exceed 91
Hey,
I'll put my name down for the next can..
- Profister
Guys, you need 2x500 ml cans/bottles per purge. It looks like I will have the product tomorrow evening.I'll put my name down for the next can.
- delicat
Ok then 2 for me and 2 for Delicanadabc...
Now get back to work and figure out exactly how to make this work on our van!
- after oil
shit, ive been looking all over for this stuff, looks like i missed out on this one
- Profister
Yes, sir!
The explanation I found on delicaclub.ru was quite simple.
Disconnect both (input and reverse) pipes from a fuel pump, connect short pipes (50-60 cm) instead and put them into a bottle with cleaner (he used Wynn's). Start the warm engine, idle for 10 min. Shut the engine, floor the pedal and start the engine. Run the engine at 1200-1500 rpm increasing and dropping rpms sharply until it burns the first 0.5 l of cleaner. Shut the engine and wait for 10 minutes. Start the engine and burn the second 0.5 l of cleaner at 2000 rpm pushing the accelerator once in a while. Put some diesel in a bottle and run the engine again to burn cleaner left in the system. Restore fuel connections.
The further discussion lead to the recommendation changing oil after the purge.
I understand that this is not the only scenario for doing it; someone with experience may contribute to this thread.
There is a high number of related videos available online, for example:
http://www.youtube.com/watch?v=hwCUEjR8ysI
http://www.youtube.com/watch?v=qNaLJiy2 ... re=related
http://www.youtube.com/watch?v=MFyfI0C- ... re=related
not really... they recommend 2 if the vehicle is in really rough shape, but for routine stuff 1 should do it.Guys, you need 2x500 ml cans/bottles per purge. It looks like I will have the product tomorrow evening.
- Profister
You asked for it and here it is. The drill was explained earlier and below are some illustrations. Good luck!
PS. I have an extra can of Lubro Moly Diesel Purge for $7.
- P4180417_resize.JPG (225.91 KiB) Viewed 5051 times
- P4180416_resize.JPG (228.53 KiB) Viewed 5046 times
- P4180419_resize.JPG (182.15 KiB) Viewed 5044 times
- P4180420_resize.JPG (186.21 KiB) Viewed 5045 times
- P4180414_resize.JPG (150.89 KiB) Viewed 5046 times
