Diesel system purge
Duke
Vehicle: 92 Delica Super Exceed
Re: Diesel system purge
Post by Duke »
Geeeezz, now I click on afteroil's link.... duhhh. :o
Post by Green1 »
Lubro Moly Diesel Purge is the stuff I used to use on the benz (I couldn't remember the name of it, but seeing the picture of the can and I definitely recognize it)
Worked wonders, but I can never find that sort of thing in the stores, they only ever seem to have the fuel additive stuff, which is not the same beast at all.
I can tell you that there was always a noticeable difference after using it on the mercedes.
Profister
Post by Profister »
Now we are talking! Thanks guys, I found it: http://vancouver.en.craigslist.ca/pts/1108689114.html
snelson
Vehicle: 92 Delica Exceed
Post by snelson »
Could you post some pics when you run this stuff through - which lines to use etc..wouldn't mind trying it out as well.
Duke wrote:Lubro Moly Diesel Purge
That's the stuff I used on my old mazda diesel.
Works great for a good hot chilly cleaning. :-D
Profister wrote:Now we are talking! Thanks guys, I found it: http://vancouver.en.craigslist.ca/pts/1108689114.html
You don't have to go out to Maple Ridge to pick it up. Just go to a Napa. They carry it.
after oil
Post by after oil »
i emailed the guy but never heard back. my napa doesnt carry it, guess il ask next time im in there
Profister
Post by Profister »
Napa in Langley quoted me $13.25/bottle. I do not need to go to Maple Ridge; the friend of mine living there will take care of this. The seller is slow negotiating the deal but hopefully next week it will be done. I am buying all 6 cans so I can share 4 of them.
Sergiy,
Now you only have 3 to deal with, I'll take the other one...thx
Delicanadabc
Vehicle: Super exceed 91
Post by Delicanadabc »
Hey,
I'll put my name down for the next can..
Profister
Post by Profister »
Guys, you need 2x500 ml cans/bottles per purge. It looks like I will have the product tomorrow evening.
Ok then 2 for me and 2 for Delicanadabc...
Now get back to work and figure out exactly how to make this work on our van! 8-)
after oil
Post by after oil »
shit, ive been looking all over for this stuff, looks like i missed out on this one
Profister
Post by Profister »
Yes, sir!
The explanation I found on delicaclub.ru was quite simple.
Disconnect both (input and reverse) pipes from a fuel pump, connect short pipes (50-60 cm) instead and put them into a bottle with cleaner (he used Wynn's). Start the warm engine, idle for 10 min. Shut the engine, floor the pedal and start the engine. Run the engine at 1200-1500 rpm increasing and dropping rpms sharply until it burns the first 0.5 l of cleaner. Shut the engine and wait for 10 minutes. Start the engine and burn the second 0.5 l of cleaner at 2000 rpm pushing the accelerator once in a while. Put some diesel in a bottle and run the engine again to burn cleaner left in the system. Restore fuel connections.
The further discussion lead to the recommendation changing oil after the purge.
I understand that this is not the only scenario for doing it; someone with experience may contribute to this thread.
There is a high number of related videos available online, for example:
http://www.youtube.com/watch?v=hwCUEjR8ysI
http://www.youtube.com/watch?v=qNaLJiy2 ... re=related
http://www.youtube.com/watch?v=MFyfI0C- ... re=related
Post by Green1 »
not really... they recommend 2 if the vehicle is in really rough shape, but for routine stuff 1 should do it.
Profister
Post by Profister »
You asked for it and here it is. The drill was explained earlier and below are some illustrations. Good luck!
PS. I have an extra can of Lubro Moly Diesel Purge for $7.
