let's see what kind of flex your Delica's got !!!!
Like the title says.. these are 4x4's ... show your Delica's flexing !
All form of Delica's welcome :M
nxski
Re: let's see what kind of flex your Delica's got !!!!
Post by nxski »
What kind of lift does that have on it? Doesn't look like the kind of flex I get out of the stock Deli... :shock:
jaggedfish
Post by jaggedfish »
My recently sold L300 before it was lifted. About the maximum articulation possible. This was at Stave Lake, BC...
Blue Gene above Stave Lake
Articulation - web.JPG (61.36 KiB) Viewed 6843 times
My new L400. Not so much "flex" but showing maximum departure angle or backwards approach angle depending which way you are driving :-D Taken over the Christmas holidays in Sechelt, BC
Zevra above Sechelt, BC
IMG_2524 - Copy.JPG (251.5 KiB) Viewed 6843 times
Tons 'o' fun!
The Miss Lil' Bitchi:
Added leaf spring and re-indexed torsion bars amounting to one and one half inch lift but still with stock anti-sway bars (stablizers).
nxski wrote:What kind of lift does that have on it? Doesn't look like the kind of flex I get out of the stock Deli... :shock:
Just a 2" lift with 31" tires
Nice flex on the rear guys, still trying to find it at the front though... 8-)
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
Delica's have Flex?? You sure?
Here is a picture of mine pre-me owning it showing off it Flex.
This is bumper flex! (This is why mine has the bed slide and tire moved behind the back axle).
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/HfftfnsK8pY&fs ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/HfftfnsK8pY?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/youtube]
thelazygreenfox
Post by thelazygreenfox »
That flex and departure angles has me wondering where I should install extra back up lights on my L400. Looks like they'd be torn off under the rear bumper. Any ideas??
Wayne
TLGF
DelicaMark
Vehicle: L400
Post by DelicaMark »
Did a little trip today and remembered seeing your post Jesse. I found an okay spot but it needed to be a bit higher to get the max flex...she had more to give!
IMG044 (640x480).jpg (222.57 KiB) Viewed 6736 times
IMG045 (640x480).jpg (262.14 KiB) Viewed 6736 times
Now for $1 can anyone guess where this was. Hint #1 is that it is in the Southern Vancouver Island area.
Looking Eastish
IMG046 (640x480).jpg (209.84 KiB) Viewed 6736 times
Looking Westish
IMG047 (640x480).jpg (229.5 KiB) Viewed 6736 times
-Mark
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
thedjjack wrote:Delica's have Flex?? You sure?
Did you find that gem after the purchase?
I always wonder if one of us has this rig: http://www.youtube.com/watch?v=Ld6c0xiVS5I
or if they have had a similar past...
thedjjack
Post by thedjjack »
Jordan wrote: Did you find that gem after the purchase?
No I saw it during negotiations help with the price. There was no real damage other then bent bush guard and a dent in the bumper. Frame ect... all fine.
nxski
Post by nxski »
I wonder about this one... http://www.youtube.com/watch?v=evKmc8ma ... r_embedded (Falco, this time I intended to not embed it so as not to take up too much space) 8-)
Is this the same lift I bought off of you? If so I'm very excited to install it. If not I'm still very excited :-D
jfarsang wrote:Just a 2" lift with 31" tires
nxski wrote:Is this the same lift I bought off of you? If so I'm very excited to install it. If not I'm still very excited :-D
Roger that. 8-)
Kuan
Vehicle: 94' L400 SWB
Post by Kuan »
DelicaMark wrote:Did a little trip today and remembered seeing your post Jesse. I found an okay spot but it needed to be a bit higher to get the max flex...she had more to give!
Looking Eastish
Looking Westish
-Mark
Road between Lake Cowichan and Port Renfrew??
Here's a few pictures of my old beloved Mitsushi showing off her flex and departure angle.
And who ever said Falco was hard headed was quite right indeed! :-D
Flex 1.jpg (105.23 KiB) Viewed 6605 times
Departure angle.jpg (101.95 KiB) Viewed 6605 times
And here's a few from a L400 while on one of our outings:
Flex 2.jpg (102.29 KiB) Viewed 6605 times
Flex 3.jpg (89.73 KiB) Viewed 6605 times
As you can see there's almost no flex at the front...
