All form of Delica's welcome
let's see what kind of flex your Delica's got !!!!
Like the title says.. these are 4x4's ... show your Delica's flexing !
- IMG_5236.jpg (583.12 KiB) Viewed 6906 times
- IMG_5237.jpg (637.38 KiB) Viewed 6906 times
- IMG_5238.jpg (675.32 KiB) Viewed 6906 times
Re: let's see what kind of flex your Delica's got !!!!
What kind of lift does that have on it? Doesn't look like the kind of flex I get out of the stock Deli...
- jaggedfish
My recently sold L300 before it was lifted. About the maximum articulation possible. This was at Stave Lake, BC...
My new L400. Not so much "flex" but showing maximum departure angle or backwards approach angle depending which way you are driving
Taken over the Christmas holidays in Sechelt, BC
Tons 'o' fun!
The Miss Lil' Bitchi:
Added leaf spring and re-indexed torsion bars amounting to one and one half inch lift but still with stock anti-sway bars (stablizers).
Just a 2" lift with 31" tiresnxski wrote:What kind of lift does that have on it? Doesn't look like the kind of flex I get out of the stock Deli...
- delicat
Nice flex on the rear guys, still trying to find it at the front though...
- thedjjack
- Vehicle: 1989 L300 HITOP!!
Delica's have Flex?? You sure?
Here is a picture of mine pre-me owning it showing off it Flex.
This is bumper flex! (This is why mine has the bed slide and tire moved behind the back axle).
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/HfftfnsK8pY&fs ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/HfftfnsK8pY?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/youtube]
thelazygreenfox
That flex and departure angles has me wondering where I should install extra back up lights on my L400. Looks like they'd be torn off under the rear bumper. Any ideas??
Wayne
TLGF
Wayne
TLGF
- DelicaMark
- Vehicle: L400
Did a little trip today and remembered seeing your post Jesse. I found an okay spot but it needed to be a bit higher to get the max flex...she had more to give!
Now for $1 can anyone guess where this was. Hint #1 is that it is in the Southern Vancouver Island area.
Looking Eastish Looking Westish -Mark
Jordan
- Vehicle: 89 low roof L300
Did you find that gem after the purchase?thedjjack wrote:Delica's have Flex?? You sure?
I always wonder if one of us has this rig: http://www.youtube.com/watch?v=Ld6c0xiVS5I
or if they have had a similar past...
- thedjjack
No I saw it during negotiations help with the price. There was no real damage other then bent bush guard and a dent in the bumper. Frame ect... all fine.Jordan wrote: Did you find that gem after the purchase?
I wonder about this one... http://www.youtube.com/watch?v=evKmc8ma ... r_embedded (Falco, this time I intended to not embed it so as not to take up too much space)Jordan wrote:Did you find that gem after the purchase?thedjjack wrote:Delica's have Flex?? You sure?
Is this the same lift I bought off of you? If so I'm very excited to install it. If not I'm still very excitedjfarsang wrote:Just a 2" lift with 31" tiresnxski wrote:What kind of lift does that have on it? Doesn't look like the kind of flex I get out of the stock Deli...
Roger that.nxski wrote:Is this the same lift I bought off of you? If so I'm very excited to install it. If not I'm still very excited
- Kuan
- Vehicle: 94' L400 SWB
Road between Lake Cowichan and Port Renfrew??DelicaMark wrote:Did a little trip today and remembered seeing your post Jesse. I found an okay spot but it needed to be a bit higher to get the max flex...she had more to give! Now for $1 can anyone guess where this was. Hint #1 is that it is in the Southern Vancouver Island area.
- delicat
Here's a few pictures of my old beloved Mitsushi showing off her flex and departure angle.
And who ever said Falco was hard headed was quite right indeed!
And here's a few from a L400 while on one of our outings:
As you can see there's almost no flex at the front...
