I bought this @ auction in Japan.
ended up getting a side exhaust done in the meantime.
2 1/2" stainless steel side exhaust
designed to accommodate larger tires
Fits Delica L300 with 2.5L turbo diesel engine
comes with rubber hanger as pictured
$310 obo
Can deliver on vancouver island or ship elsewhere.
cheers colby
FS: Stainless Steel Side Exhaust
cobsweb
- Vehicle: 92 Exceed
- side exhaust2.jpg (52.68 KiB) Viewed 3949 times
- side exhaust.jpg (49.96 KiB) Viewed 3951 times
- Vehicle: -
Re: FS: Stainless Steel Side Exhaust
That's an interesting exhaust
Does it bolt right onto the flange/downpipe? That means it comes out right behind the front tire?
Have you tried how loud it is?
cobsweb
It bolts directly onto the existing downpipe flange.
imagine its plenty loud being that its a straight pipe flared out.
probably hear more turbo spool than anything else.
no airflow restriction here.
exhaust arrives on may 25th along with a few more L300 ladders.
cheers colby
cheers colby
What diameter is the little nub in between the flange and the 2.5" pipe ?
cobsweb
I'll fit this exhaust as soon received
probably wont keep it as pyro bung already welded into current exhaust
from the looks of it, the "little nub" sits far enough away from the flange so as not to interfere with the nuts/springs.
cheers colby
I see what your getting at, but judging from the quality of construction I doubt such a flaw.jfarsang wrote:What diameter is the little nub in between the flange and the 2.5" pipe ?
cheers colby
- fishslapper
- Vehicle: 1994 lwb l400
pretty clearly looks like 2 1/4 to start for an inch or so then - 2 1/2 inches ....
just a guess.
just a guess.
The Mighty Boosh !!
cobsweb
pretty sure there is not enough room between the springs for 2 1/2" all the way to the flange.
check out this thread for some pics of the area.
http://www.delica.ca/forum/another-exha ... ht=exhaust
even fexlboi's newest 2 1/2" SS side exhaust narrows to clear the springs.
cheers colby
cheers colby
