FS: Stainless Steel Side Exhaust
cobsweb
Vehicle: 92 Exceed
Post by cobsweb »
I bought this @ auction in Japan.
ended up getting a side exhaust done in the meantime.
2 1/2" stainless steel side exhaust
designed to accommodate larger tires
Fits Delica L300 with 2.5L turbo diesel engine
comes with rubber hanger as pictured
$310 obo
Can deliver on vancouver island or ship elsewhere.
cheers colby
side exhaust2.jpg (52.68 KiB) Viewed 3953 times
side exhaust.jpg (49.96 KiB) Viewed 3955 times
Vehicle: -
Re: FS: Stainless Steel Side Exhaust
Post by fexlboi »
That's an interesting exhaust 8-)
Does it bolt right onto the flange/downpipe? That means it comes out right behind the front tire?
Have you tried how loud it is?
cobsweb
Vehicle: 92 Exceed
Post by cobsweb »
It bolts directly onto the existing downpipe flange.
imagine its plenty loud being that its a straight pipe flared out.
probably hear more turbo spool than anything else.
no airflow restriction here.
exhaust arrives on may 25th along with a few more L300 ladders.
cheers colby
What diameter is the little nub in between the flange and the 2.5" pipe ?
cobsweb
Vehicle: 92 Exceed
Post by cobsweb »
I'll fit this exhaust as soon received
probably wont keep it as pyro bung already welded into current exhaust
jfarsang wrote:What diameter is the little nub in between the flange and the 2.5" pipe ?
I see what your getting at, but judging from the quality of construction I doubt such a flaw.
from the looks of it, the "little nub" sits far enough away from the flange so as not to interfere with the nuts/springs.
cheers colby
fishslapper
Vehicle: 1994 lwb l400
Post by fishslapper »
pretty clearly looks like 2 1/4 to start for an inch or so then - 2 1/2 inches ....
just a guess.
The Mighty Boosh !!
cobsweb
Vehicle: 92 Exceed
Post by cobsweb »
pretty sure there is not enough room between the springs for 2 1/2" all the way to the flange.
check out this thread for some pics of the area.
http://www.delica.ca/forum/another-exha ... ht=exhaust
even fexlboi's newest 2 1/2" SS side exhaust narrows to clear the springs.
cheers colby
