Hi Folks,
I had a shifter cable break on me. No really. It broke. Right off. I can prove it!
My Deli is a 5 speed, model year 89, though actually built in 88, and it turns out that early in the '89 model year, Mitsubishi switched to a different style of shifter cable. Naturally, my Deli used the older style cable which nobody stocks. I checked. Nobody. 'ts-OK though because the newer model fits and Glen (CCAutos) has 'em. The newer cable doesn't fit well but if you lube your parts up enough , the water bushing on the newer model will fit through the boot on the old model.
So in summation, if you too have an early '89 Deli with a 5 speed manual transmission and you bust a shifter cable, the newer style cables from mid to late '89 and later can be made to fit the shifter/boot assemblies of Delis built in early '89 or earlier.
							Broken shifter cable on 5 speed?
Does your Mitsubishi L300 make a strange noise?  Need wheel alignment specs?
				delicanuck
Post by delicanuck »
Brett,
89 Exceed,
There are really only 10 kinds of people in the world;
Those who understand binary and those who don't.
						89 Exceed,
				Jump to
	- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
