1992 Delica Super Exceed for Parts
As the title says, parting out a 1992 Super Exceed.
Email with any requests to: gerry.martselos@gmail.com
- Luna-Sea
Re: 1992 Delica Super Exceed for Parts
Where are you located?
What's the paint scheme?
The vehicle is stored in the Okanagan, about 45 mins from Vernon. I'm willing to ship, though any cost is the buyer's responsibility. I can get the parts to North Van at no cost if you're patient.
It's grey over silver.
The engine is currently getting compression tested and removed.
Parts removed from the vehicle and available (photos available/coming). Email if you're interested in these or anything else and I'll send a picture and a price.
-Forged deep dish Rims and 33" BFG tires:
http://kelowna.en.craigslist.ca/pts/1467145128.html
Flares available but require repair.
Lift Kit with (4) four additional Rancho rear shocks (8 shocks total)
LSD
Upgraded Sway Bars with end links
Rear Brakes: Drums, shoes, cylinders
Front Brake calipers and pads
JAOS Fog lights
Stainless Exhaust (needs tip)
Most Glass
Rear spoiler (Dark Grey metallic)
Rear gate struts
High mount/third stop light
Lighting
Super Exceed Grey microfiber interior.
Rear and Middle Captains Chairs: 9-9.5/10
Front seats 7-8/10
Aftermarket front bumper w/ lights
Front Radiator guard plate
Knardi Steering wheel
Boost Gauge
Extra plastic clips for power shades (shades themselves are gone)
Windshield visor
Much more to come.
Email Gerry.martselos@gmail.com with any requests.
LSD
JAOS Fog lights
Most Glass
Rear gate struts
Lighting
Front seats 7-8/10
Boost Gauge
Windshield visor
Much more to come.
- Delica Parts 061.jpg (85.82 KiB) Viewed 7774 times
- Delica Parts 046.jpg (91.89 KiB) Viewed 7769 times
- Delica Parts 051.jpg (89.46 KiB) Viewed 7769 times
- Delica Parts 071.jpg (75.67 KiB) Viewed 7763 times
- Delica Parts 080.jpg (76.44 KiB) Viewed 7757 times
- Delica Parts 033.jpg (116.22 KiB) Viewed 7987 times
- Delica Parts 017.jpg (195.08 KiB) Viewed 7978 times
- TAIT
- Vehicle: 93 Exceed CrystalLite
sent you a pm...
- almac
i am currently looking for a drivers' side mirror in black.
just curious. what do you want for the stainless exhaust?
i live outside of vernon, so coming to you for pickup wont be an issue.
al
al
Meanman
pm sent
More photos added, many more on the way.
No compression test results for the motor just yet, but I have the tester (finally!) and will be completing the test ASAP.
MOTOR/TRANS SOLD
All ACCESSORIES SOLD
Original post:
Great news, motor was tested today and results are in!
Every Cylinder hit 275PSI or more. I was using a compression tester that presses into the glow plug hole with a rubber cone shaped stopper to seal it and hold pressure, so not the most ideal. If anything, the results would only improve using a better tester:) I cranked the starter over and let it "bump" 5 or 6 times to get a solid reading. I did quite a few tests of each cylinder to get a good average between nearly 280psi and the minimum was 270psi, some cylinders went higher and lower on occasion but not consistently. Photos of results are attached.
This motor hasn't been run for over a month and the test was done dry (no fluids added) to see actual compression figures. I don't know what this motor should be (anyone?), but the owner of the compression tester was surprised it was that high, and all the cylinders were even, which is the main thing. Every compression tester will read differently, and the one I had on loan was less than stellar.
Motor will include: Engine Block and internals, oil pan, front cover, head, complete valvetrain, and valve cover. Anything else still attached is bonus:)
I can bring it to North Van, at no cost if you're patient, otherwise shipping is on your tab.
SOLD
Now may be a good time to pick up other maintenance items you may foresee a need for soon, while they're available and cheap, instead of when you're in a pinch. The more you take off my hands, the better the deal I'll give. Payment by Paypal (add 3%), direct deposit at RBC, or cash.
Original post:
SOLD
- Cyl 4.JPG (207.84 KiB) Viewed 7677 times
- Cyl 3.JPG (204.73 KiB) Viewed 7676 times
- Cyl 2.JPG (235.2 KiB) Viewed 7666 times
- Cyl 1.JPG (197.49 KiB) Viewed 7672 times
More parts and photos.
Prices go down substantially the more you take.
- Rear Brakes: Drums, pads, cylinders
Pads are near new, still have white grease on them.
Rear cylinders look newer as well, seals all look good,
drums look great and measured at about 253-254mm (max diameter is 256mm).
Asking $250 for everything - Delica Parts 080.jpg (76.44 KiB) Viewed 7662 times
- Front Brakes: Calipers and Pads
Pads look to be about 60% remaining, maybe more.
No leaks were apparent
Asking $200 - Delica Parts 071.jpg (75.67 KiB) Viewed 7659 times
more parts.
- Sway Bars: Upgraded(?) bars, mounts and endlinks
Front: 30mm Mounts ok, Endlinks could use new bushings (~$20 for rubber)
Rear: 20mm Mounts ok, Endlinks look good, no play
$100 each or $175 for both - Delica Parts 046.jpg (91.89 KiB) Viewed 7650 times
- SOLD
Radiator and new Rad cap
In good working order, never overheated, never leaked.
Asking $200 - Delica Parts 108.jpg (36.55 KiB) Viewed 7645 times
- Delica Parts 103.jpg (35.13 KiB) Viewed 7647 times
- AC "Rad" and fan
Held pressure before removal and fan was functioning.
$100 - Delica Parts 102.jpg (34.88 KiB) Viewed 7643 times
There are plenty of interior pieces in good shape, and most glass.
- Rear "Delica" reflector panel
$100 - Delica Parts 063.jpg (90.71 KiB) Viewed 7620 times
- SOLD
Timing Belt Kit: Timing Belt, Balance Shaft belt, Tensioners, Cam Pulley.
This was just installed about 3 months ago, and has done just over 2,000kms. It's near new and now broken in, would make an excellent kit to have on hand in the vehicle for those doing long trips with their Delica, or anyone who wants a timing belt that's been run in slightly and proven to be good.
$250
(Waterpump also available for $150, no pic yet) - Delica Parts 045.jpg (96.18 KiB) Viewed 7616 times
- High mount stop light.
$50 - Delica Parts 057.jpg (57.64 KiB) Viewed 7621 times
- SOLD - Stainless Exhaust (damaged)
Full length with polished muffler. Needs a new tip, has some dents. 2" from turbo, then 2 1/4" Mandrel Bent Stainless tubing all the way back. Rubber hangers included.
$200 - Delica Parts 051.jpg (89.46 KiB) Viewed 7614 times
- Rancho RS9000 Shocks, Adjustable damping
2 Front, 2 Rear. A little rough looking on the outside, but shafts look good and they functioned fine. 5 settings.
$200 for all 4 - Delica Parts 077.jpg (74.5 KiB) Viewed 7612 times
More parts, more pics.
- SOLD
Alternator and Vacuum pump
$200 - Delica Parts 129.jpg (107.49 KiB) Viewed 7486 times
- SOLD
Tensioners - Delica Parts 125.jpg (162.9 KiB) Viewed 7491 times
- SOLD
Timing and Balance shaft Belt - Delica Parts 124.jpg (120.13 KiB) Viewed 7485 times
- SOLD
Water pump
This was just installed about 3 months ago, and has done just over 2,000kms. It's near new and now broken in.
$150 - Delica Parts 122.jpg (145.94 KiB) Viewed 7480 times
- Emblems
Make an offer - Delica Parts 135.jpg (176.56 KiB) Viewed 7471 times
- SOLD
Skid Plate
All hardware included. Very nice piece in good shape.
$200 - Delica Parts 119.jpg (179.62 KiB) Viewed 7473 times
- SOLD
Front Bumper and Lights
I'll include the lights that are on it, though there's no guarantee they work.
I planned to gravel guard it. It's in good shape but not perfect. I think smooth and shiny surfaces on the exterior of a vehicle is somewhat ridiculous...though I love chrome as much as any one else, it should be used as trim. Gravel guard is textured so it covers up flaws instead of highlighting them. It can easily be repaired with a simple respray as it blends well, a $10 can will last a decade for touch-ups. And it absorbs some of the energy when things like rocks hit it, lessening the impact. All good things that paint or chrome can't really do, I think the stuff should be on everything:)
I'm not sure how the bumper went on, or what should have been included. It looks as though there's the major brackets and maybe one side is different than the other? I can't see it being too difficult for any decent fabricator to mount up.
$400 - Delica Parts 109.jpg (157.63 KiB) Viewed 7465 times
- Rear Windshield with Seal
$150 - Delica Parts 100.jpg (129.95 KiB) Viewed 7450 times
- SOLD
Transmission cooler
$100 - Delica Parts 104.jpg (118.95 KiB) Viewed 7449 times
- Boost Guage
With Mounting Tab (not a pod)
$50 - Delica Parts 133.jpg (99.25 KiB) Viewed 7450 times
- Rear Spoiler
Notched for Rear Ladder
$250 - Delica Parts 012.jpg (89.37 KiB) Viewed 7444 times
- SOLD
Fan.Acc belts
$50 - Delica Parts 130.jpg (109.87 KiB) Viewed 7444 times
- SOLD
Glow plugs
$75 for 4 - Delica Parts 126.jpg (198.48 KiB) Viewed 7443 times
- SOLD
EGR Valve
$50 - Delica Parts 105.jpg (157.67 KiB) Viewed 7431 times
- Rear passenger window glass
Tinted
$100 - Delica Parts 095.jpg (88.22 KiB) Viewed 7433 times
- Sliding Door Glass
Tinted
$100 - Delica Parts 094.jpg (101.44 KiB) Viewed 7433 times
- Middle row driver side window glass
Tinted
$100 each - Delica Parts 096.jpg (117.86 KiB) Viewed 7431 times
- Crystal Lite Roof Glass (Rear, both sides)
$100 each - Delica Parts 097.jpg (93.03 KiB) Viewed 7427 times
- almac
hey Mav, is your tranny an auto or 5SPD?
i might be in need of a 5SPD.
al
al
