1992 Delica Super Exceed for Parts
Mavro
Vehicle: Delica/Landcruiser/240SX
Post by Mavro »
As the title says, parting out a 1992 Super Exceed.
Email with any requests to: gerry.martselos@gmail.com
Luna-Sea
Re: 1992 Delica Super Exceed for Parts
Post by Luna-Sea »
Where are you located?
What's the paint scheme?
Mavro
Post by Mavro »
The vehicle is stored in the Okanagan, about 45 mins from Vernon. I'm willing to ship, though any cost is the buyer's responsibility. I can get the parts to North Van at no cost if you're patient.
It's grey over silver.
The engine is currently getting compression tested and removed.
Parts removed from the vehicle and available (photos available/coming). Email if you're interested in these or anything else and I'll send a picture and a price.
-Forged deep dish Rims and 33" BFG tires:
http://kelowna.en.craigslist.ca/pts/1467145128.html
Flares available but require repair.
Lift Kit with (4) four additional Rancho rear shocks (8 shocks total)
LSD
Upgraded Sway Bars with end links
Rear Brakes: Drums, shoes, cylinders
Front Brake calipers and pads
JAOS Fog lights
Stainless Exhaust (needs tip)
Most Glass
Rear spoiler (Dark Grey metallic)
Rear gate struts
High mount/third stop light
Lighting
Super Exceed Grey microfiber interior.
Rear and Middle Captains Chairs: 9-9.5/10
Front seats 7-8/10
Aftermarket front bumper w/ lights
Front Radiator guard plate
Knardi Steering wheel
Boost Gauge
Extra plastic clips for power shades (shades themselves are gone)
Windshield visor
Much more to come.
Email Gerry.martselos@gmail.com with any requests.
Delica Parts 061.jpg (85.82 KiB) Viewed 7798 times
Delica Parts 046.jpg (91.89 KiB) Viewed 7793 times
Delica Parts 051.jpg (89.46 KiB) Viewed 7793 times
Delica Parts 071.jpg (75.67 KiB) Viewed 7787 times
Delica Parts 080.jpg (76.44 KiB) Viewed 7781 times
Delica Parts 033.jpg (116.22 KiB) Viewed 8011 times
Delica Parts 017.jpg (195.08 KiB) Viewed 8002 times
TAIT
Vehicle: 93 Exceed CrystalLite
Post by TAIT »
sent you a pm...
almac
Vehicle: '91 Delica "Tessen"
Post by almac »
i am currently looking for a drivers' side mirror in black.
just curious. what do you want for the stainless exhaust?
i live outside of vernon, so coming to you for pickup wont be an issue. :-)
al
Meanman
Post by Meanman »
pm sent
Mavro
Post by Mavro »
More photos added, many more on the way.
No compression test results for the motor just yet, but I have the tester (finally!) and will be completing the test ASAP.
Mavro
Post by Mavro »
MOTOR/TRANS SOLD
All ACCESSORIES SOLD
Original post:
Great news, motor was tested today and results are in!
Every Cylinder hit 275PSI or more. I was using a compression tester that presses into the glow plug hole with a rubber cone shaped stopper to seal it and hold pressure, so not the most ideal. If anything, the results would only improve using a better tester:) I cranked the starter over and let it "bump" 5 or 6 times to get a solid reading. I did quite a few tests of each cylinder to get a good average between nearly 280psi and the minimum was 270psi, some cylinders went higher and lower on occasion but not consistently. Photos of results are attached.
This motor hasn't been run for over a month and the test was done dry (no fluids added) to see actual compression figures. I don't know what this motor should be (anyone?), but the owner of the compression tester was surprised it was that high, and all the cylinders were even, which is the main thing. Every compression tester will read differently, and the one I had on loan was less than stellar.
Motor will include: Engine Block and internals, oil pan, front cover, head, complete valvetrain, and valve cover. Anything else still attached is bonus:)
I can bring it to North Van, at no cost if you're patient, otherwise shipping is on your tab.
SOLD
Now may be a good time to pick up other maintenance items you may foresee a need for soon, while they're available and cheap, instead of when you're in a pinch. The more you take off my hands, the better the deal I'll give. Payment by Paypal (add 3%), direct deposit at RBC, or cash.
Cyl 4.JPG (207.84 KiB) Viewed 7701 times
Cyl 3.JPG (204.73 KiB) Viewed 7700 times
Cyl 2.JPG (235.2 KiB) Viewed 7690 times
Cyl 1.JPG (197.49 KiB) Viewed 7696 times
Mavro
Post by Mavro »
More parts and photos.
Prices go down substantially the more you take.
Rear Brakes:  Drums, pads, cylinders<br /><br />Pads are near new, still have white grease on them.<br />Rear cylinders look newer as well, seals all look good,<br />drums look great and measured at about 253-254mm (max diameter is 256mm).<br /><br />Asking $250 for everything
Delica Parts 080.jpg (76.44 KiB) Viewed 7686 times
Front Brakes:  Calipers and Pads<br /><br />Pads look to be about 60% remaining, maybe more.<br />No leaks were apparent<br /><br />Asking $200
Asking $200
Delica Parts 071.jpg (75.67 KiB) Viewed 7683 times
Mavro
Post by Mavro »
more parts.
Sway Bars:  Upgraded(?) bars, mounts and endlinks<br /><br />Front: 30mm  Mounts ok, Endlinks could use new bushings (~$20 for rubber)<br />Rear: 20mm  Mounts ok, Endlinks look good, no play<br /><br />$100 each or $175 for both
Delica Parts 046.jpg (91.89 KiB) Viewed 7674 times
SOLD<br /><br />Radiator and new Rad cap<br /><br />In good working order, never overheated, never leaked.  <br /><br />Asking $200
SOLD
Asking $200
Delica Parts 108.jpg (36.55 KiB) Viewed 7669 times
Delica Parts 103.jpg (35.13 KiB) Viewed 7671 times
AC &quot;Rad&quot; and fan<br /><br />Held pressure before removal and fan was functioning.<br /><br />$100
AC "Rad" and fan
$100
Delica Parts 102.jpg (34.88 KiB) Viewed 7667 times
Mavro
Post by Mavro »
There are plenty of interior pieces in good shape, and most glass.
Rear &quot;Delica&quot; reflector panel<br /><br />$100
Rear "Delica" reflector panel
$100
Delica Parts 063.jpg (90.71 KiB) Viewed 7644 times
SOLD<br /><br />Timing Belt Kit:  Timing Belt, Balance Shaft belt, Tensioners, Cam Pulley.<br /><br />This was just installed about 3 months ago, and has done just over 2,000kms.  It's near new and now broken in, would make an excellent kit to have on hand in the vehicle for those doing long trips with their Delica, or anyone who wants a timing belt that's been run in slightly and proven to be good.<br /><br />$250<br /><br />(Waterpump also available for $150, no pic yet)
SOLD
$250
Delica Parts 045.jpg (96.18 KiB) Viewed 7640 times
High mount stop light.<br /><br />$50
$50
Delica Parts 057.jpg (57.64 KiB) Viewed 7645 times
SOLD - Stainless Exhaust (damaged)<br /><br />Full length with polished muffler.  Needs a new tip, has some dents.  2&quot; from turbo, then 2 1/4&quot; Mandrel Bent Stainless tubing all the way back.  Rubber hangers included.<br /><br />$200
Full length with polished muffler. Needs a new tip, has some dents. 2" from turbo, then 2 1/4" Mandrel Bent Stainless tubing all the way back. Rubber hangers included.
$200
Delica Parts 051.jpg (89.46 KiB) Viewed 7638 times
Rancho RS9000 Shocks, Adjustable damping<br /><br />2 Front, 2 Rear.  A little rough looking on the outside, but shafts look good and they functioned fine.  5 settings.<br /><br />$200 for all 4
$200 for all 4
Delica Parts 077.jpg (74.5 KiB) Viewed 7636 times
Mavro
Post by Mavro »
More parts, more pics.
SOLD<br /><br />Alternator and Vacuum pump<br /><br />$200
SOLD
$200
Delica Parts 129.jpg (107.49 KiB) Viewed 7510 times
SOLD<br /><br />Tensioners
SOLD
Tensioners
Delica Parts 125.jpg (162.9 KiB) Viewed 7515 times
SOLD<br /><br />Timing and Balance shaft Belt
SOLD
Delica Parts 124.jpg (120.13 KiB) Viewed 7509 times
SOLD<br /><br />Water pump<br /><br />This was just installed about 3 months ago, and has done just over 2,000kms. It's near new and now broken in.<br /><br />$150
SOLD
Water pump
$150
Delica Parts 122.jpg (145.94 KiB) Viewed 7504 times
Emblems<br /><br />Make an offer
Emblems
Make an offer
Delica Parts 135.jpg (176.56 KiB) Viewed 7495 times
SOLD<br /><br />Skid Plate<br /><br />All hardware included.  Very nice piece in good shape.<br /><br />$200
SOLD
Skid Plate
$200
Delica Parts 119.jpg (179.62 KiB) Viewed 7497 times
SOLD<br /><br />Front Bumper and Lights<br /><br />I'll include the lights that are on it, though there's no guarantee they work. <br /><br />I planned to gravel guard it.  It's in good shape but not perfect.  I think smooth and shiny surfaces on the exterior of a vehicle is somewhat ridiculous...though I love chrome as much as any one else, it should be used as trim.  Gravel guard is textured so it covers up flaws instead of highlighting them.  It can easily be repaired with a simple respray as it blends well, a $10 can will last a decade for touch-ups.  And it absorbs some of the energy when things like rocks hit it, lessening the impact.  All good things that paint or chrome can't really do, I think the stuff should be on everything:)<br /><br />I'm not sure how the bumper went on, or what should have been included.  It looks as though there's the major brackets and maybe one side is different than the other?  I can't see it being too difficult for any decent fabricator to mount up.<br /><br />$400
SOLD
$400
Delica Parts 109.jpg (157.63 KiB) Viewed 7489 times
Mavro
Post by Mavro »
Rear Windshield with Seal<br /><br />$150
$150
Delica Parts 100.jpg (129.95 KiB) Viewed 7474 times
SOLD<br /><br />Transmission cooler<br /><br />$100
SOLD
Transmission cooler
$100
Delica Parts 104.jpg (118.95 KiB) Viewed 7473 times
Boost Guage<br /><br />With Mounting Tab (not a pod)<br /><br />$50
Boost Guage
$50
Delica Parts 133.jpg (99.25 KiB) Viewed 7474 times
Rear Spoiler<br /><br />Notched for Rear Ladder<br /><br />$250
Rear Spoiler
$250
Delica Parts 012.jpg (89.37 KiB) Viewed 7468 times
SOLD<br /><br />Fan.Acc belts<br /><br />$50
SOLD
Fan.Acc belts
$50
Delica Parts 130.jpg (109.87 KiB) Viewed 7468 times
SOLD<br /><br />Glow plugs<br /><br />$75 for 4
SOLD
Glow plugs
$75 for 4
Delica Parts 126.jpg (198.48 KiB) Viewed 7467 times
Mavro
Post by Mavro »
SOLD<br /><br />EGR Valve<br /><br />$50
SOLD
EGR Valve
$50
Delica Parts 105.jpg (157.67 KiB) Viewed 7455 times
Rear passenger window glass<br /><br />Tinted<br /><br />$100
Tinted
$100
Delica Parts 095.jpg (88.22 KiB) Viewed 7457 times
Sliding Door Glass<br /><br />Tinted<br /><br />$100
Sliding Door Glass
Tinted
$100
Delica Parts 094.jpg (101.44 KiB) Viewed 7457 times
Middle row driver side window glass<br /><br />Tinted<br /><br />$100 each
Tinted
$100 each
Delica Parts 096.jpg (117.86 KiB) Viewed 7455 times
Crystal Lite Roof Glass (Rear, both sides)<br /><br />$100 each
$100 each
Delica Parts 097.jpg (93.03 KiB) Viewed 7451 times
almac
Post by almac »
hey Mav, is your tranny an auto or 5SPD?
i might be in need of a 5SPD. :shock:
al
