1992 Delica 10-Pass/Cargo/Work Van 124 kms 5-Spd $5,500 SALE
- MardyDelica
For sale: 1992 Delica 10-Pass/Cargo/Work Van 124,000 kms.2WD 5-Spd = 1 ton Van
Price: $ 5,500 = In Richmond Stock
Amazing Auto Imports Ltd.
DL # 30843
Stock # A-00210
Mardy ( Mardydelica )
T- 604-247-2111 / 604-720-6144
Did the ff service & Details of this Delica:
1.) New Timing belt ( Mitsubishi 2 pcs), new water pump Japan, 2 new bearing, 4 new seal (orig mits), thermostat;
2.) Change all fluid oil, gear oil, antifreeze;
3.) New headlight with 4 new osram bulb (Germany);
4.) Comply & registered with day time running light;
5.) 4 brand new tires;
6.) undercarriage has been re-greased;
7.) Grade 3.5 & B, No rust under-carriage
8.) New sway bar bushings: upper & lower (Poly-urethane);
9.) 4 Cyl ,2.5 liter Turbo Diesel;
10.) Has some dents
11.) 10 passenger bench seat model, inside is very clean;
12.) Runs very good & stable
13.) Have both side middle sliding door open very rare as see in the picture
14.) Easy to fit 10Ft X 4 Ft ply-wood
15.) good for handy man or convert it as a camper
16.) High roof model
17.) Has sliding window, middle & rear
18.) All seat is in mint condition like new, as you can see the previous owner put a cover plastic to protect the seat.
DL # 30843
Stock # A-00210
10.) Has some dents
- DSCF1307.JPG (105.34 KiB) Viewed 6151 times
- DSCF1309.JPG (121.49 KiB) Viewed 6147 times
- DSCF1310.JPG (101.47 KiB) Viewed 6143 times
- DSCF1311.JPG (117.68 KiB) Viewed 6142 times
- DSCF1312.JPG (104.36 KiB) Viewed 6136 times
- DSCF1313.JPG (103.08 KiB) Viewed 6137 times
- DSCF1314.JPG (141.02 KiB) Viewed 6127 times
- TardisDeli
Re: 1992 Delica 10-Pass/Cargo/Work Van 124,000 kms. 2WD 5-Spd
Hi Mardy, is the van LONGER than our usual delica? If so, it would be a better van to convert to camper. Thanks, Christine.
Yes, that is a rare long wheelbase L300, you can tell by the fact that the rear side windows are the same length as the mid side window.is the van LONGER than our usual delica?
neat to see a 10 seater and one with dual sliding doors too!
- MardyDelica
yes, ths is a longwheel base delica. same engine as our delica with turbo, except its just 2wd, but the unique on this is that it has dual sliding door.
i have 2 available of this delica in stock.
its good to convert as a camper van. like i say 10ft & 4ft plywood will fit easy, no problem at all. also its a high roof, both of them has air conditioning on it.
cheers:
cheers:
- MardyDelica
Re: 1992 Delica 10-Pass/Cargo/Work Van 124 kms 5-Spd $5,500 SALE
Hi, this delica L300 is on Sale:
$5,500 complied; good for handyman or using it for farm vehicle 10 pass. trubo diesel on it with complete 10 seat on it;
Cheers;
Cheers;
Is there an emblem on it saying its a delica?
- MardyDelica
its a delica but we can put delica emblem on it if you buy this van no problem
cheers;
cheers;
Sorry I am new here. So all L300's are Delica's?
Yes.
Mistubishi Delica L300
Mitsubishi - manufacturer / make
Delica - model name
L300 - model number
Delica - model name
L300 - model number
- dah_hunter
These are awesome..
I had a Hiace one like this in Africa..
dual sliding doors, 10 seater.. with the Jump seats..
Nice price.
Nice price.
Its all about the Right Way:
http://import-era.com
- MardyDelica
hi, thanks,
this van is nice no rust under & the price is reasonable.
still up for sale for a low price
cheers;
cheers;
