1992 Delica 10-Pass/Cargo/Work Van 124 kms 5-Spd $5,500 SALE
MardyDelica
Post by MardyDelica »
For sale: 1992 Delica 10-Pass/Cargo/Work Van 124,000 kms.2WD 5-Spd = 1 ton Van
Price: $ 5,500 = In Richmond Stock
Amazing Auto Imports Ltd.
DL # 30843
Stock # A-00210
Mardy ( Mardydelica )
T- 604-247-2111 / 604-720-6144
Did the ff service & Details of this Delica:
1.) New Timing belt ( Mitsubishi 2 pcs), new water pump Japan, 2 new bearing, 4 new seal (orig mits), thermostat;
2.) Change all fluid oil, gear oil, antifreeze;
3.) New headlight with 4 new osram bulb (Germany);
4.) Comply & registered with day time running light;
5.) 4 brand new tires;
6.) undercarriage has been re-greased;
7.) Grade 3.5 & B, No rust under-carriage
8.) New sway bar bushings: upper & lower (Poly-urethane);
9.) 4 Cyl ,2.5 liter Turbo Diesel;
10.) Has some dents
11.) 10 passenger bench seat model, inside is very clean;
12.) Runs very good & stable
13.) Have both side middle sliding door open very rare as see in the picture
14.) Easy to fit 10Ft X 4 Ft ply-wood
15.) good for handy man or convert it as a camper
16.) High roof model
17.) Has sliding window, middle & rear
18.) All seat is in mint condition like new, as you can see the previous owner put a cover plastic to protect the seat.
TardisDeli
Re: 1992 Delica 10-Pass/Cargo/Work Van 124,000 kms. 2WD 5-Spd
Post by TardisDeli »
Hi Mardy, is the van LONGER than our usual delica? If so, it would be a better van to convert to camper. Thanks, Christine.
Post by Green1 »
Yes, that is a rare long wheelbase L300, you can tell by the fact that the rear side windows are the same length as the mid side window.
neat to see a 10 seater and one with dual sliding doors too!
MardyDelica
yes, ths is a longwheel base delica. same engine as our delica with turbo, except its just 2wd, but the unique on this is that it has dual sliding door.
i have 2 available of this delica in stock.
its good to convert as a camper van. like i say 10ft & 4ft plywood will fit easy, no problem at all. also its a high roof, both of them has air conditioning on it.
cheers:
MardyDelica
Re: 1992 Delica 10-Pass/Cargo/Work Van 124 kms 5-Spd $5,500 SALE
Hi, this delica L300 is on Sale:
$5,500 complied; good for handyman or using it for farm vehicle 10 pass. trubo diesel on it with complete 10 seat on it;
Cheers;
Slimdog
Vehicle: 2000 L300 LWB
Post by Slimdog »
Is there an emblem on it saying its a delica?
MardyDelica
its a delica but we can put delica emblem on it if you buy this van no problem
cheers;
Slimdog
Post by Slimdog »
Sorry I am new here. So all L300's are Delica's?
Yes.
Mistubishi Delica L300
Mitsubishi - manufacturer / make
Delica - model name
L300 - model number
dah_hunter
Post by dah_hunter »
These are awesome..
I had a Hiace one like this in Africa..
dual sliding doors, 10 seater.. with the Jump seats..
Nice price.
Its all about the Right Way:
http://import-era.com
MardyDelica
hi, thanks,
this van is nice no rust under & the price is reasonable.
still up for sale for a low price
cheers;
