Loosey goosey t-case lever
Big-Bird
Vehicle: 96 PE8W Spacegear
Post by Big-Bird »
Here's a first for me. The t-case lever linkage broke today. I suspect a pin fell out when I shifted into 4WD mode. I have never had this happen on any 4x4 i have owned.
Gives me a reason to install the new super select switches (flashing yellow light) on top of the tranny. This should prove interesting!
thelazygreenfox
Re: Loosey goosey t-case lever
Post by thelazygreenfox »
BB
I'll wait for some nice warm weather before climbing under to check those switches. How did you make out??
TLWF
Big-Bird
Post by Big-Bird »
Have the new switches.
Now i need a warm day. Started snowing the day I was gonna roll under my Deli on the creeper. The lnikage is not borken thankfully, just a pin fell out. Still tight work space. Probably gonna have to lower the tranny and engine to make some hand-space at the tranny tunnel.
(not a fun job!!!!)
Big-Bird
Post by Big-Bird »
Got the t-case lever opened up today.......not good. Cracked and broke the end off. Need a new t-case shift lever now.
Thankfully it was easy to remove and the carpet didn't need to be pulled to do it. With the e-brake unbolted and moved aside it gave adequate access to the 6-10mm bolts that hold the boot in place and the 3-12mm nuts hold the lever and plate to the top of the transfer case.
vtin
Vehicle: Mitsubishi Pajero 2.8 TDI
Post by vtin »
You must shift into 4x4 with great enthusiasm ;)
I'd just weld it back together or ask a welder to do it.
Should take only a few minutes.
