does anyone has any suggestion ?
Claude
Undo the lug nuts first?claude wrote:I was going to change my tires this afternoon but end up not able to take the rim off. I kicked the tire and bang them a with a hammer but no luck.![]()
thanks , I will try all of them tomorrow if the temperature is no too cold . Today it was -9 an right know it already -14RichD wrote:Undo the lug nuts first?claude wrote:I was going to change my tires this afternoon but end up not able to take the rim off. I kicked the tire and bang them a with a hammer but no luck.![]()
does anyone has any suggestion ?![]()
Put two or three lug nuts back on. Don't tighten them all the way. Drop the jack; the rim should pop loose under load.
Thanks I will try this one too. As for the sledge it is not on my listthedjjack wrote:heat the rim with a torch if you have one...usually they corrode on the hub or the mounting surface.
Either paint or no-bind after you get them off.
I would be careful with a sledge as you might damage the rim....
Bien sure On va le faireRichD wrote:Faut q'ca brasse!
X2 on the rubber mallet and 2x4 trick.92pajero wrote:Any vehicle that has a dissimilar metal rim in comparison to the drive train will have difficulties with the rims getting "stuck" to the drive train. If anyone suggest loosening lug nuts and going for a short drive, loosening and dropping the jack and that sort do not understand how a rim really works in supporting the vehicles weight. The lug nuts only retain the rim onto the axle or hub, the center opening of the rim is coincidentally the exact size for the axle or hub. Reason being the rim supports the majority of the load on this, the lugs/lug nuts only keep the wheel tightly fixed to the hub/axle. It was mentioned to add heat via a torch to the rim, once again this is not a wise decision, it was mentioned to loosen and shake the vehicle or to use a 2x4 and a sledge these are the 2 best solutions. Once the rim is off paint is not the best but go and get some copper or silver anti-seize, its a paste that you put onto brake components to lubricate and stop corrosion, been using it for 20+years and never a problem. PS the sledge trick works best from outside in and rotate the tire every couple hits so that it will work loose if required.
Kelly
