Rims won't come off
claude
Vehicle: Delica Exceed jasper
Rims won't come off
Post by claude »
I was going to change my tires this afternoon but end up not able to take the rim off. I kicked the tire and bang them a with a hammer but no luck. :shock:
does anyone has any suggestion ?
Claude
Leo Tolstoy
RichD
Re: Rims won't come off
Post by RichD »
claude wrote:I was going to change my tires this afternoon but end up not able to take the rim off. I kicked the tire and bang them a with a hammer but no luck. :shock:
Undo the lug nuts first? :-D
Put two or three lug nuts back on. Don't tighten them all the way. Drop the jack; the rim should pop loose under load.
lopar
Vehicle: L400 (soon)
Post by lopar »
or "short" non-agressive drive around the block with all lug nuts loose but still on
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
or an aggressive smack on the tire with a sledge hammer
claude
Post by claude »
thanks , I will try all of them tomorrow if the temperature is no too cold . Today it was -9 an right know it already -14 :-(
Leo Tolstoy
thedjjack
Vehicle: 1989 L300 HITOP!!
Post by thedjjack »
heat the rim with a torch if you have one...usually they corrode on the hub or the mounting surface.
Either paint or no-bind after you get them off.
I would be careful with a sledge as you might damage the rim....
claude
Post by claude »
thedjjack wrote:heat the rim with a torch if you have one...usually they corrode on the hub or the mounting surface.
Thanks I will try this one too. As for the sledge it is not on my list :-)
Leo Tolstoy
Profister
Post by Profister »
Claude: this is a simple one. Do as RichD suggested and then shake the van sideways. :M
RichD
Post by RichD »
Faut q'ca brasse!
Mr. Flibble
Post by Mr. Flibble »
I bought a rubber mallet for this purpose and beat the bajeebus out if the rims, but load plus loose lug nuts should work fine. I often grease the contact points to prevent the rim sticking like this.
I'm going with Golf Cart and Mister Flibble, take a mallet to them ~ you'll probably find you don't have to whack them too hard, maybe use a two by four against the wheel and whack the two by four.
claude
Post by claude »
RichD wrote:Faut q'ca brasse!
Bien sure On va le faire
Leo Tolstoy
92pajero
Vehicle: 92 pajero exceed
Post by 92pajero »
Any vehicle that has a dissimilar metal rim in comparison to the drive train will have difficulties with the rims getting "stuck" to the drive train. If anyone suggest loosening lug nuts and going for a short drive, loosening and dropping the jack and that sort do not understand how a rim really works in supporting the vehicles weight. The lug nuts only retain the rim onto the axle or hub, the center opening of the rim is coincidentally the exact size for the axle or hub. Reason being the rim supports the majority of the load on this, the lugs/lug nuts only keep the wheel tightly fixed to the hub/axle. It was mentioned to add heat via a torch to the rim, once again this is not a wise decision, it was mentioned to loosen and shake the vehicle or to use a 2x4 and a sledge these are the 2 best solutions. Once the rim is off paint is not the best but go and get some copper or silver anti-seize, its a paste that you put onto brake components to lubricate and stop corrosion, been using it for 20+years and never a problem. PS the sledge trick works best from outside in and rotate the tire every couple hits so that it will work loose if required.
Kelly
"Why are some peoples mouths in overdrive but their minds are in neutral"
a sledge hammer and 2x4 is the only safe solution. You wack the rubber, not the rim.
all the rest have the possibility to cause damage
tonydca
Post by tonydca »
92pajero wrote:Any vehicle that has a dissimilar metal rim in comparison to the drive train will have difficulties with the rims getting "stuck" to the drive train. If anyone suggest loosening lug nuts and going for a short drive, loosening and dropping the jack and that sort do not understand how a rim really works in supporting the vehicles weight. The lug nuts only retain the rim onto the axle or hub, the center opening of the rim is coincidentally the exact size for the axle or hub. Reason being the rim supports the majority of the load on this, the lugs/lug nuts only keep the wheel tightly fixed to the hub/axle. It was mentioned to add heat via a torch to the rim, once again this is not a wise decision, it was mentioned to loosen and shake the vehicle or to use a 2x4 and a sledge these are the 2 best solutions. Once the rim is off paint is not the best but go and get some copper or silver anti-seize, its a paste that you put onto brake components to lubricate and stop corrosion, been using it for 20+years and never a problem. PS the sledge trick works best from outside in and rotate the tire every couple hits so that it will work loose if required.
Kelly
X2 on the rubber mallet and 2x4 trick.
But FYI, OP - if you have OEM Mitsubishi rims, then the above info is true. Such wheels are called "hub-centric" since the centre bore of the wheel matches the wheel's hub diameter perfectly.
However, some aftermarket wheels have larger-than-hub centre bores, and rely on the lugs to do the heavy work of centring the rim and bearing the weight. They are called "lug-centric". And doing what RichD suggested by loosening the lugs nuts and dropping the vehicle will indeed have the desired effect of popping the wheel free.
http://www.tradeunion.com/website_blue/ ... KICE-Faq13
Return to “L400 Technical”
