Dash color change!
Mr. Pistachio
Vehicle: L400 LWB Super Exceed
Dash color change!
Post by Mr. Pistachio »
Hey y'all,
It was time for a change! I'm done with the green. Early 90's green is not my cup of tea especially that I got my drivers in 2003 so it's not like I had an emotionnal attachment to kitch or old fashion!
To complete the project I had to find LED that would be plug and play as much as possible because I wanted the project to require minimal mods. SO I thought! There's about 3 billion type of LED and all of them could ish work.
A thing to remember about LED is that they're not made to work on 12 volt unless specified otherwise
The other thing to remember is that LED are polarized so if they don't light up, have them do a 180 in the wedge and they'll work!
Something I've noticed: Blue is way more intense then red.
The hardest part was the gear selector because I had to weld resistance on the circuit board and also because the light that illumanate all the letters is also a ''master resistance'' to the hole dash. Go figure. Basically if that light is not there, none of the lights will illuminate and it pisses me off because this circuit only work with incadescent light! F*** So until I find a solution I'm stuck with a yellow white and it looks terrible instead of having a clean white white!
SO I went for the all red dash with a couple of blue accent!! Blue could've also been done but my radio unit I bought was either green (beurk) or red.
basically everything is red except the flasher and Park Neutral Reverse
The only green left is the clock!
So here's the list
Cluster:
3 x T10 9 SMD 12v
16 x T1.5 5mm (give or take depending on what you want to change color) 12v
The back of the cluster. The 3 big wedges are the T10 9SMD
Heating unit
3 x Neo wedge 4mm 12v
2 x plain LED with two wires
The temperature unit! # neo wedge and two LED that DON'T need a resistance because it was green led that were there before for the outside air and rear control button
Rear of heating unit. You can see the 3 gray neowedge LED
Instrument panel
1 x plain LED with two wires
1 x 1K ohm resistance
2 x T10 5 SMD 12v
Glove box, cigarette lighter and ash tray
3 x T1.5 LED - Here you only need the LED and not the wedge
Gear selector (here's the fun)
7 x plain LED with two wires
7 x 1K ohm resistance
The gear selector lights. On the far left is that stupid light that control all illumination of the car #@$%?&
The gear selector color GREEN filter. I've used paint thinner to take off the color. Be sure not to wipe off the O/D
Under the gear selector where I've weld the resistance. To do so I also had to cut in the board to bypass the connection!!!
Dome reading light
2 x T10 9SMD 12v
The pictures:
in the reply
Mr. Pistachio
Re: Dash color change!
The pictures
The T10 wedge
The T10 wedge
The T1.5 wedge
The T1.5 wedge
Plain LED which are usually 1.6v
Neo Wedge
Neo Wedge
well done Mr. A 8-)
solanoid
Vehicle: 95 deli SE- aka Rolls Rice
Post by solanoid »
You Sir, are a technical wizard. I draw the line at changing a household light bulb :-)
deli1733
Vehicle: 1991 L-300 94 Pajero LWB
Post by deli1733 »
That is awsome, nice work.
trecar
Vehicle: 96 Delica Exceed
Post by trecar »
nicely done, i have been planning on doing mine in the near future, question where did you get your bulbs for everything?
Trevor
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
Mr P. If you have that much free time, Stretch could use some help!! :)
TardisDeli
Post by TardisDeli »
Dude, you gotta move back to BC, and do more camping treks with us again like that great Braelorne trip we did, your delica won't remember how to rough road camp now that you've made it so glamorous. Hugs, Christine.
Christine
Mr. Pistachio
Dudette! Thanks! That I know, no need to to rub it in more. East coast is nowhere close to BC 4whellin!
madmazda
Vehicle: 1994 l400
Post by madmazda »
JESUS..... Awesome, nice work....
prairiefire
Vehicle: 1995 L400 Delica SWB
Post by prairiefire »
Wow!
Mr. Pistachio
almac
Vehicle: '91 Delica "Tessen"
Post by almac »
cool mod.
i would love to do this on my L300. :-)
al
Mr. Pistachio
almac wrote:cool mod.
Well do it!
trecar
Post by trecar »
what luminous intensity of neo wedges did you go with?
Trevor
