Dash color change!
				Mr. Pistachio
- Vehicle: L400 LWB Super Exceed
Dash color change!
Hey y'all,
It was time for a change! I'm done with the green. Early 90's green is not my cup of tea especially that I got my drivers in 2003 so it's not like I had an emotionnal attachment to kitch or old fashion!
To complete the project I had to find LED that would be plug and play as much as possible because I wanted the project to require minimal mods. SO I thought! There's about 3 billion type of LED and all of them could ish work.
A thing to remember about LED is that they're not made to work on 12 volt unless specified otherwise
The other thing to remember is that LED are polarized so if they don't light up, have them do a 180 in the wedge and they'll work!
Something I've noticed: Blue is way more intense then red.
The hardest part was the gear selector because I had to weld resistance on the circuit board and also because the light that illumanate all the letters is also a ''master resistance'' to the hole dash. Go figure. Basically if that light is not there, none of the lights will illuminate and it pisses me off because this circuit only work with incadescent light! F*** So until I find a solution I'm stuck with a yellow white and it looks terrible instead of having a clean white white!
SO I went for the all red dash with a couple of blue accent!! Blue could've also been done but my radio unit I bought was either green (beurk) or red.
basically everything is red except the flasher and Park Neutral Reverse
The only green left is the clock!
So here's the list
Cluster:
3 x T10 9 SMD 12v
16 x T1.5 5mm (give or take depending on what you want to change color) 12v Heating unit
3 x Neo wedge 4mm 12v
2 x plain LED with two wires
Instrument panel
1 x plain LED with two wires
1 x 1K ohm resistance
2 x T10 5 SMD 12v
Glove box, cigarette lighter and ash tray
3 x T1.5 LED - Here you only need the LED and not the wedge
Gear selector (here's the fun)
7 x plain LED with two wires
7 x 1K ohm resistance Dome reading light
2 x T10 9SMD 12v
The pictures:
in the reply
So here's the list
Cluster:
3 x T10 9 SMD 12v
Instrument panel
2 x T10 5 SMD 12v
2 x T10 9SMD 12v
The pictures:
in the reply
				- IMG_3141_DxO.jpg (59.19 KiB) Viewed 12057 times
				Mr. Pistachio
Re: Dash color change!
The pictures
				- The T10 wedge
- T10.jpg (79.17 KiB) Viewed 12056 times
				- The T1.5 wedge
- T1.5.jpeg (5.8 KiB) Viewed 12056 times
				- Plain LED which are usually 1.6v
- plain.jpg (223.7 KiB) Viewed 12056 times
				- Neo Wedge
- Neo.jpg (5.83 KiB) Viewed 12056 times
				- IMG_3144_DxO.jpg (45.47 KiB) Viewed 12056 times
				- IMG_3142_DxO.jpg (51.48 KiB) Viewed 12056 times
well done Mr. A
- solanoid
You Sir, are a technical wizard. I draw the line at changing a household light bulb
HeathenForce-http://www.ultragod.com/
						- deli1733
That is awsome, nice work.
				trecar
- Vehicle: 96 Delica Exceed
nicely done, i have been planning on doing mine in the near future, question where did you get your bulbs for everything?
Trevor
						Trevor
- Super Exceeded
- Vehicle: 1993 L300S
Mr P. If you have that much free time, Stretch could use some help!!   :)
						- TardisDeli
Dude, you gotta move back to BC, and do more camping treks with us again like that great Braelorne trip we did, your delica won't remember how to rough road camp now that you've made it so glamorous.  Hugs, Christine.
							Christine
				Mr. Pistachio
Dudette! Thanks! That I know, no need to to rub it in more. East coast is nowhere close to BC 4whellin!
				madmazda
- Vehicle: 1994 l400
JESUS..... Awesome, nice work....
				prairiefire
- Vehicle: 1995 L400 Delica SWB
				Mr. Pistachio
- almac
cool mod.
i would love to do this on my L300.
al
						al
				Mr. Pistachio
Well do it!almac wrote:cool mod.
				trecar
what luminous intensity of neo wedges did you go with?
Trevor
						Trevor
