WTB F&R gearing from 5-speed, poss. trade
Moderators: delicanuck, mark
- Leafster
- Vehicle: L300 Deli
I'm looking to gear down the Deli. Has anyone retro-fitted a gearset from the 5-speed to an auto? With the larger tires the Deli is pretty doggy and I want to be able to tow a small trailer again.
Re: WTB F&R gearing from 5-speed, poss. trade
gearing is the same 4.875 in the differentials
you'll want to swap the auto trans out for a 5-spd
can be done and has been done. just takes some work
- Leafster
I guess I was mistaken from other posts that the differential ratios are lower on the manual tranny but I see that it's not. I actually adjusted the kick-down cable and the van is much better now that it's holding a lower gear for longer.
I haven't had any acceleration problems with 31" tires on my auto l300 (apart from the usual).
Sounds like you found your problem.
- Leafster
I did, having the transmission holding back longer helped a lot. It's also easier to manipulate the shifting points now so the van accelerates much better.
