Installing an aftermarket oil temperature sensor
RichD
Post by RichD »
So I'm looking to install an oil temperature sensor like this one - in the sump. I'd like to avoid invasive and hacked modifications of the oil pan.
One approach is to use the oil level sensor hole, like this aftermarket solution for a completely different vehicle. Another I considered was putting something inline on the oil return hose.
Below is an image of the oil pan. I haven't been able to get a part number on the oil level sensor or a detailed illustration. Thoughts?
Richard Dagenais
Mr. Flibble
Re: Installing an aftermarket oil temperature sensor
Post by Mr. Flibble »
RichD wrote:So I'm looking to install an oil temperature sensor like this one - in the sump. I'd like to avoid invasive and hacked modifications of the oil pan.
You could tee off your oil pressure sender for your low oil warning light. It only requires a "splitter".
Why don't you get an oil pressure sensor instead ? Much more valuable than a temp sensor on these engines.
RichD
Post by RichD »
jfarsang wrote:Why don't you get an oil pressure sensor instead ? Much more valuable than a temp sensor on these engines.
I want oil and water temperature for sure, especially in extreme cold and hot weather situations.
As for oil pressure being more important...
I agree. But why not both?
Richard Dagenais
good point :-D
I like 3 gauges. Not overkill but looks nice. oil pressure, pyro, boost.
More can look good too ... what other gauges do you have planned ?
RichD
Post by RichD »
jfarsang wrote:good point :-D
You mean how many sensors. Gauges are expensive, sensors and switches are cheap.
http://www.delica.ca/forum/pyro-and-boo ... 552#p73552
Richard Dagenais
