Tire size with a lift
Re: Tire size with a lift
That was one of the things I was wondering about. It seems pretty labour intensive. When I sent an email about the lift I was told it was between 4 and 6 inches but it looked more like a 3" lift. I think I'll keep shopping around. I can't afford to buy yet and it seems that the cheap Deli lift will soon be a thing of the past.
- Super Exceeded
- Vehicle: 1993 L300S
Got 33's X 12.5 on mine with a 5 inch lift!
But you all knew that.
And yup, they're all right, going past 3 inches bring lotsa head aches
- a1022100958a.jpg (6.59 KiB) Viewed 5352 times
He's out to lunch (current seller parting it out). It's a 2" lift. I should know as I installed it when I owned it.nxski wrote:That was one of the things I was wondering about. It seems pretty labour intensive. When I sent an email about the lift I was told it was between 4 and 6 inches but it looked more like a 3" lift. I think I'll keep shopping around. I can't afford to buy yet and it seems that the cheap Deli lift will soon be a thing of the past.
Jezoos man ! How on earth is that little engine pushing 6 meaty tires ?! I have to admit. It looks verySuper Exceeded wrote:Got 33's X 12.5 on mine with a 5 inch lift!
But you all knew that.![]()
Oh I believe you, he seemed very unsure about the components.jfarsang wrote:He's out to lunch (current seller parting it out). It's a 2" lift. I should know as I installed it when I owned it. Christmas is around the corner. Shoot me a pm and I'll put one aside for the new year for you.
PM sent...
I apologize for my odd chain of comments, the computer is being difficult...
http://www.amazon.com/Mickey-Thompson-S ... 95&sr=1-35
http://www.amazon.com/Pro-Comp-98-Gloss ... 98&sr=1-96
http://www.amazon.com/Eagle-Alloys-185- ... 8&sr=1-251
Any opinions on these rims? I appears from my research that the lower the offset the more the wheel sticks out which in turn would provide a wider stance? Assuming this would I be correct in saying that the 2 rims with an offset just over 3" would be the better of the 3, or do I have that backwards? Assuming that these will even work, which would the informed people suggest?
The max backspacing you want it 3.75" inches on a 15x8 rim. With this rim and a 10.5" wide tire you may not be able to open your sliding door all the way.
The best option is to get a 7" wide tire with 3.75" backspacing. That is the ideal setup.
Good to know, I'm trying to source some 'extenders' and flares for the sliding door and arches so that I can have the wheels stick out as much as possible. Is the 3.75 max backspacing due to torque or fit? I can't seem to find a diagram that explains this very well, I might have to bug someone at the next meet.
fit and if you go further out you'll have more wear and tear on the driveline components up front
I'll stick with your recommendations then. More wear in never a good thing.
Carp
- Vehicle: 94' L-400 Super Exceed
Hi, just about to get a 2" lift kit installed next week. My existing rims are 15"x7" and if I measured correctly the offset is 4 3/4".
Will that offset still allow me to install 31x10.5x15 duratracks or will they rub on the inside of the tire? I've read that 3 3/4" is the minimum back offset, whats the max?
- IMGP0943res.jpg (75.61 KiB) Viewed 5011 times
I haven't tested 4.75" backspacing on a 7" wide rim with 10.5" wide tire.
You won't know if it rubs unless you fit it.
I know on an L300 10.5" tires on the stock 6.5" rim does run the upper control arm on the inside of the tire. I believe the stock rim is 4.25" backspacing.
Jordan
- Vehicle: 89 low roof L300
Do 31" tires decrease RPMS on hills or is it tougher to push the big rubber?
Yes to both of your q's
