Tire size with a lift
nxski
Re: Tire size with a lift
Post by nxski »
That was one of the things I was wondering about. It seems pretty labour intensive. When I sent an email about the lift I was told it was between 4 and 6 inches but it looked more like a 3" lift. I think I'll keep shopping around. I can't afford to buy yet and it seems that the cheap Deli lift will soon be a thing of the past. :-(
Super Exceeded
Vehicle: 1993 L300S
Post by Super Exceeded »
Got 33's X 12.5 on mine with a 5 inch lift!
But you all knew that. :-D
And yup, they're all right, going past 3 inches bring lotsa head aches
nxski wrote:That was one of the things I was wondering about. It seems pretty labour intensive. When I sent an email about the lift I was told it was between 4 and 6 inches but it looked more like a 3" lift. I think I'll keep shopping around. I can't afford to buy yet and it seems that the cheap Deli lift will soon be a thing of the past. :-(
He's out to lunch (current seller parting it out). It's a 2" lift. I should know as I installed it when I owned it. :-D Christmas is around the corner. Shoot me a pm and I'll put one aside for the new year for you. :M
Super Exceeded wrote:Got 33's X 12.5 on mine with a 5 inch lift!
Jezoos man ! How on earth is that little engine pushing 6 meaty tires ?! I have to admit. It looks very 8-)
nxski
Post by nxski »
nxski
Post by nxski »
jfarsang wrote:He's out to lunch (current seller parting it out). It's a 2" lift. I should know as I installed it when I owned it. Christmas is around the corner. Shoot me a pm and I'll put one aside for the new year for you.
Oh I believe you, he seemed very unsure about the components.
PM sent...
nxski
Post by nxski »
I apologize for my odd chain of comments, the computer is being difficult...
nxski
Post by nxski »
http://www.amazon.com/Mickey-Thompson-S ... 95&sr=1-35
http://www.amazon.com/Pro-Comp-98-Gloss ... 98&sr=1-96
http://www.amazon.com/Eagle-Alloys-185- ... 8&sr=1-251
Any opinions on these rims? I appears from my research that the lower the offset the more the wheel sticks out which in turn would provide a wider stance? Assuming this would I be correct in saying that the 2 rims with an offset just over 3" would be the better of the 3, or do I have that backwards? Assuming that these will even work, which would the informed people suggest?
The max backspacing you want it 3.75" inches on a 15x8 rim. With this rim and a 10.5" wide tire you may not be able to open your sliding door all the way.
The best option is to get a 7" wide tire with 3.75" backspacing. That is the ideal setup.
nxski
Post by nxski »
Good to know, I'm trying to source some 'extenders' and flares for the sliding door and arches so that I can have the wheels stick out as much as possible. Is the 3.75 max backspacing due to torque or fit? I can't seem to find a diagram that explains this very well, I might have to bug someone at the next meet. 8-)
fit and if you go further out you'll have more wear and tear on the driveline components up front
nxski
Post by nxski »
I'll stick with your recommendations then. More wear in never a good thing. :-)
Carp
Vehicle: 94' L-400 Super Exceed
Post by Carp »
Hi, just about to get a 2" lift kit installed next week. My existing rims are 15"x7" and if I measured correctly the offset is 4 3/4".
Will that offset still allow me to install 31x10.5x15 duratracks or will they rub on the inside of the tire? I've read that 3 3/4" is the minimum back offset, whats the max?
I haven't tested 4.75" backspacing on a 7" wide rim with 10.5" wide tire.
You won't know if it rubs unless you fit it.
I know on an L300 10.5" tires on the stock 6.5" rim does run the upper control arm on the inside of the tire. I believe the stock rim is 4.25" backspacing.
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
Do 31" tires decrease RPMS on hills or is it tougher to push the big rubber?
Yes to both of your q's
