Sap/resin stains... or bumps....
impalator
Vehicle: L300
Post by impalator »
Not actually stains... more like bumps... I had the Van parked under some trees last Summer and sap must have dripped down onto the Van. I wash the Van more or less regularly - but never really got into the polishing thing... now I just polished like heck on Sunday and these sap-bumbs won't come off... I tried to scrape some off with my fingernails - but that is virtually futile and useless... I then tried to polish right on the bump and I don't think it had any impact whatsoever... I guess, the only good thing is that somehow the bumps are almost glass-clear and it is therefore the same color as the Van... but I would still like to get that stuff off....
Does anybody have any ideas - obviously don't want to use a chisel or a screwdriver... :-)
Chris
Re: Sap/resin stains... or bumps....
WD40 and patience. Just use your finger, not a scrubpad.
Wash with soap and rinse afterwards.
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
Rubbing alcohol perhaps?
RichD
Post by RichD »
Hot water and soap worked for me in the past. There are pressure-wash places that use hot water not cold, if you shop around. "Green" car washes use cold water.
Those trees are all over Vancouver. Someone told me that the city bought a huge order of them back in the 60s, not realizing that they dump sap all over cars.
Richard Dagenais
Luna-Sea
Post by Luna-Sea »
Goo Gone
or citrus-ly similar
http://www.magicamerican.com/googone.aspx
Right On 8-)
butter or cooking oil and tree pitch comes right off...
fishslapper
Vehicle: 1994 lwb l400
Post by fishslapper »
lighter fluid.....
The Mighty Boosh !!
Luna-Sea
Post by Luna-Sea »
Also,
Some turtle wax product
http://www.canadiantire.ca/AST/browse/4 ... ?locale=en
1/2 price this weekend ,cheap cheap
Right On! 8-)
claybar :M
Wildtrak
Vehicle: 1989 Delica L300 4D56T
Post by Wildtrak »
Hi!
It maybe worth trying kerosene. I used that in removing bubble gum, bitumen residues and some sap. It is generally gentle on car finishes. As a rule of thumb tho, test on a small spot first.
Wildtrak
impalator
Vehicle: L300
Post by impalator »
Well, thanks for all the tips... I will be doing some research/tests on the coming weekend... I will proceed in the following order :-)
WD40 and Finger - if it doesn't do the trick:
Rubbing Alcohol - if it doesn't do the trick:
Hot Water and Soap - if it doesn't do the trick:
Goo Gone or Citrus-ly - if it doesn't do the trick:
Butter or Cooking oil - if it doesn't do the trick:
Lighter Fluid - if it doesn't do the trick:
Some Turtle Wax Product - if it doesn't do the trick:
Claybar - if it doesn'd to the trick:
Kerosene - and if this doesn't do it... :
I'll take the angle grinder and "grind it out" :-)
Thanks for all the inputs - pretty sure that one or the other option will do it...
Chris
DeliTan
Member's Photo Album: http://www.delica.ca/Photos/index.php?cat=13029
Vehicle: 94 L400 LWB Crystal
Post by DeliTan »
Side note:
Just so you folks know, I think what you are talking about isn't sap.
Maybe you don't wanna know what it is...
john
Erebus
Vehicle: 1992 Super Exceed
Post by Erebus »
impalator wrote:Well, thanks for all the tips... I will be doing some research/tests on the coming weekend... I will proceed in the following order :-)
Chris
If claybar doens't work, a claymore will. Might damage other parts too, but would make a great YouTube video.
