Side trim strip.
Modsqwad
Vehicle: 91 Deli & KLR 650
Side trim strip.
Post by Modsqwad »
I am looking for a photo of a deli with the strip of plastic trim that runs the length of the van removed. I want to do this to mine when I
paint it but my wife thinks it will " look like crap" if I do. I would like to show her an example. Thanks.
Andy Wilson
Re: Side trim strip.
Andy,
No pictures for you (I think Josh removed his) but if I recall by removing it you end up with a bunch of holes where the trim was clipped in place...
Luna-Sea
Post by Luna-Sea »
Hey,
This is Josh's sweet silver bullet.
there would be some small holes.
easy enough to fill.
more pics here
http://www.delica.ca/forum/smither-s-ho ... -2852.html
Land Shark was pre-trim era
Noels pics 09 041 (Medium).jpg (47.4 KiB) Viewed 3011 times
I like the look myself,less flying rock protection I guess...
Taking them off for the paint job would give you better results no?
Then you could make up your mind (and maybe hers),win win.
Give the fastners some WD-40 (Adrock Juice) therapy a few days
before and a few times,they like to shear off sometimes and not play nice.
Right On Hombre! 8-)
Modsqwad
Post by Modsqwad »
Muchisimas gracias amigo's. I will run these past Leigh and let her decide. I think it will help give it a nice clean look and its so cheap to
do down here. When she's done I'll posts a couple photo's.
Andy
docsavage
Vehicle: Deliless...
Post by docsavage »
Hey Andy,
Josh put his strip back on, mine never had it from the factory:
I personally like it without, less dirt and water trapped in behind it to start corroding.
James
1989 Delica P24W Exceed
Panasonic CQ-TX5500W
jrman
Side trim strip.
Post by jrman »
Logging in away from home but will take pic later.
Not so bad me thinks, I've left all trim off since cutting to fit the 31" - my intention is the fill the holes and rhinoline the lower 12 inch or so (to mach my roof!)...but that would only be after I finish my front bumper which might be 2012 at the current rate of progress ! :-D
Sean in North Van
1991 Delica Exceed - Scoobus
