Hi Gang,
If you search the forum for "wet floors" you will get sent to
viewtopic.php?t=58&highlight=wet+floors
which includes a link to:
http://www.mdocuk.co.uk/forums/viewtopic.php?t=12646
another of the ubiquitous posts by Bruce the Good, AKA Mystery Machine. It includes wet floor fixing  instructions that are so good even I could do it. I would add only one note to those instructions as follows:
DO NOT remove the screw that is under the windscreen rubber. Loosen it a turn or so only. The body panel will slide out from under it. If you do remove that screw, within an hour or so you will be inventing all sorts of colourful new epithets that you hope the neighbour kids won't learn, or if they do, you hope they don't tell mom where. If anyone is really stumped by those seized screws, and if you live in or near North Van, I have the impact tool. Works pretty good provided you haven't already converted those Reed and Prince heads into tube drives.  I also have a lot of semi mastic body putty left if anyone wants to go whole hog on the whole repair thing.  It has better gap filling properties and stays more flexible than tube goop over the long haul.  I coatedthe area with with the tube goop (can't think of the name) then packed the gap with putty, then smeared goop over everything with the prescribed downward motion. Bob is my mother's brother.
About that ice on the floors thing, well, I've heard of ice and I understand that some people like it in their drinks but I'm unclear on why you would want to drink off the floor of your car.
