Here we go
The Japanese have the problem sussed out and here are the pictures to prove it
Remove the indicators & headlights first
Then the corner panel above them
Then you need to do a bit of painting
Then a bit of sealing as this is the leaking seam that lets the footwell fill with water
AND tidy up the sealant before you put it all back together again
AND they did this as group while on a trip...how very Japanese....how very Deli.....
Check your drive side floor and Good Luck.
Kevin
Call me BCDelica-less
