Installed the receiver/hitch today!
definingdigital
Vehicle: Delica
Post by definingdigital »
I've wanted to put a receiver on my delica for a while. For towing a trailer or bike racks etc.. Finally got around to ordering a kit from Steven @ Rising Sun Imports, and to be honest, it was one of the easiest installs I've done. I spent hours on the phone here in Edmonton trying to get a shop to weld something up or modify a receiver for the 1992 Delica, but nobody wanted to touch it. Getting the kit from Stephen was super easy, and very happy with the result! :-D Uses 3 existing bolt holes.
NOTE: I actually had to move the bolts to the first 2 settings on the large middle part to make a little more room for when I lifted up the spare tire.... in the pic shown it has the bolts in the 1 and 3 holes..
Lapprentis
Post by Lapprentis »
I have the very same one: installation was flawless. It is very well made and strong ! My bike carrier goes there too :)
Lapprentis :M
Snomad74
Vehicle: 1990 Delica L300
Post by Snomad74 »
Hey definingdigital, thanks for posting about your hitch install...looks awesome. I've been meaning to do the same thing since I bought my Delica 4 months ago, but haven't found the right one yet, and that setup you have looks solid. Aside from mtn bikes, I'm looking to haul a 300 lb (ya know, like 140 kg in more advanced civilizations;) moto on a hitch rack. Any idea what the tongue weight rating is for your hitch receiver? What is the make/model? Cheers for the beta.
Crankshaft Culture
Vehicle: 1989 Delica
Post by Crankshaft Culture »
That looks great, and very stout.
Out of curiosity, does anyone know if the Curt hitches for the Mitsubishi Van that was imported into the U.S. work on a Delica?
http://www.curtmfg.com/part/11611
I know it's a little class 1, but I'm only looking to pull a light trailer.
Randoramma
Vehicle: 87 L300 4wd 4D56
Post by Randoramma »
definingdigital wrote:I've wanted to put a receiver on my delica for a while. For towing a trailer or bike racks etc.. Finally got around to ordering a kit from Steven @ Rising Sun Imports, and to be honest, it was one of the easiest installs I've done. I spent hours on the phone here in Edmonton trying to get a shop to weld something up or modify a receiver for the 1992 Delica, but nobody wanted to touch it. Getting the kit from Stephen was super easy, and very happy with the result! :-D Uses 3 existing bolt holes.
Would you please be willing to post a part or catalog number? I want to order the same for my 87. Thank you!
definingdigital
Vehicle: Delica
Just call stephen @ rising sun imports to order..
http://www.rs-import.ca/infodesk/custom_center.php
Lapprentis
It is a Very good quality part, easy to install. The only drawback is that any oversized tire, even with the stock rim/wheel, will make the spare tire holder not to fits perfectly into its original position.
Lapprentis :M
definingdigital
Vehicle: Delica
Lapprentis wrote:It is a Very good quality part, easy to install. The only drawback is that any oversized tire, even with the stock rim/wheel, will make the spare tire holder not to fits perfectly into its original position.
Lapprentis :M
I believe I ran into the same issue. I just had to drill a hole a bit lower for the tire mount, so the tire would fit under. Might need a different fix for a larger tire.
weelsey
Member's Photo Album: http://www.delica.ca/Photos/profile.php?uid=15295
Vehicle: '90 2.5l high roof exceed
Post by weelsey »
Very nice, and I wish that was on mine!
I realize I don't have a rear sway bar on my delica..
I bet I could fit a 235/75-15 behind that hitch, where as my Reese 37096 multi-fit will not allow it despite all my efforts to force it. But it's robust, and I believe my solution to carry the spare will be to install a moto-hauler I inherited from a motorhome and strap the spare to it as a temporary solution, despite the extra weight. at least the tire is then not on the roof!
Snomad74 wrote:I'm looking to haul a 300 lb moto on a hitch rack
The reese is 500lb rated. I took a pic of the spec sticker but it turned out blurry. it's this one: https://www.summitracing.com/int/parts/ ... /overview/
I would try to sell you my moto-bar if you were closer, Snomad74!
mbergerooo
Vehicle: L300
Post by mbergerooo »
Hi Weelsey,
Did I read this correctly? Do you have the Reese 37096 on your Delica? Did you have to customize it to get it to work?
MB
