A/C Advice
izack98
Re: A/C Advice
Post by izack98 »
I removed my rear evaporator (I called it a condenser - but the guys at the a/c shop corrected me). My system kept leaking out the gas I put in.
I could see a bit of oil collecting around the two fittings where they connected to the aluminum block of the evaporator. I removed it and the evaporator looks like new. I took it in to have it tested, which they can't do until after the weekend.
I am hoping it is just the o-rings that need replacing.
I have been reading on the UK site and several people have had issues with the aluminum block where the a/c hoses connect (circled in red) at the evaporator cracking and leaking. They indicate welding it has had about 60:40 result of success.
It looks like this:
L400 Rear Evaporator
Does anyone have the spec capacity for oil volume for an A/C system on a 97 L400? It has front and rear A/C.
I found the specs for the gas volume (955 grams) by searching but can't seem to find the oil volume.
islander20
Vehicle: 1994 L400 LWB
Re: A/C Advice
Post by islander20 »
I believe your system should already have oil in it, most of which will be in the compressor. When I had mine recharged I asked for some oil to be added, the tech added an oz and warned against adding to much. Can cause lots of issues. Thats my understanding anyways.
izack98
Re: A/C Advice
Post by izack98 »
Thanks Islander20
Once I fix the leak, the system will be evacuated and recharged. Does the evacuation remove the oil as well?
If not then I wont have to worry about it. Maybe just add a little to replace what's leaked out.
islander20
Re: A/C Advice
The vacuum will cause the water to boil off and exit as vapour, the oil won't evaporate under vacuum. As its being vacuumed you can add some oil to the low pressure side I believe, the vacuum will pull it through. Not 100% sure if oil was added to the low pressure side or high pressure side. Are you doing the recharge and vacuum yourself?
izack98
Re: A/C Advice
Post by izack98 »
No, I am getting a shop to do the vacuuming and recharge once I repair the system. They will know how to add a bit of oil. I imagine very little was lost in the leak so it won't need much at all - if any.
Thanks for the info. That does make sense. I was thinking the oil would be pulled out as well.
izack98
Re: A/C Advice
Post by izack98 »
Just called the rad shop and my evaporator isn't leaking...whew!
Two thumbs up to the guys at Surrey Radiator at 64/King George. Great to deal with and friendly service. They were swamped and explained it would be a couple of days before they could get to it. They performed as promised. I'd go back there.
I need 2 new o-rings to replace the ones where the A/C lines connect to the evaporator. I'm pretty sure that's where my leak is. They guys at the rad shop found the smaller of the 2 but say the larger one is an odd size which they couldn't match.
Anyone have any suggestions where to begin looking? I'll try Lordco and the regular places but in case they don't I don't know where else to look.
thelazygreenfox
Re: A/C Advice
Post by thelazygreenfox »
izack
All the shops that deal orings buy here
Fluidseal
Unit 5
1680 Bridgeport rd Richmond
604 278 6808
fluidseal@sealsonline.com
Good luck
TLWF
Return to “L400 Technical”
