looking for lift kit
garyo
Vehicle: 91 exceed
Re: looking for lift kit
Post by garyo »
this is a picture of the longer shackles next to the stockers, on the right.much stronger and uses a tie bar in the middle to keep everything from twisting.
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
garyo wrote:this is a picture of the longer shackles next to the stockers, on the right.much stronger and uses a tie bar in the middle to keep everything from twisting.
Many of us would like to know what you'd charge for a set of shackles and upper ball joint spacers, for the DIY crowd?
Regards,
Kev
Image Call me BCDelica-less
jaggedfish
Post by jaggedfish »
Me three!
I like the stance and the fact the torsion bars don't require maxing. Does this affect the driveshaft lengths at all or does the lift sort of pivot around that? And... would you consider going higher like the Mystery Machine?
When my Deli grows up it wants to be like the "M/M"! 8-)
macka
Vehicle: none yet
Post by macka »
Has anyone thought of doing an SAS? Also there are Pajero/L200 liftkits out of the Phillipines that would work. They have all new upper and lower A-arms, and different springs. I'd like to see someone build them for here in NA.
patty
Vehicle: delica chamonix
Post by patty »
yeah garyo, if you can do it for cheeper then a grand im deffinatly in, specialy if its under 500 bones.
VSM
Vehicle: 1992 Delica Lifted and Tuned
Post by VSM »
Under 500 and you can do it yourself.
The complete kit stands your truck up right. Come down to the shop. 2 lift kits available. Kits costs $400. Install another $600. Bring cash.
vancouversupermoto.com 858 Powell street,
Mark.
delica 304
Vehicle: 1992 delica GLX
Post by delica 304 »
Hmm, sounds like the perfect birthday present. I'll have to wait 'till the end of March though :|
garyo
Vehicle: 91 exceed
Post by garyo »
also comes with new lower rear shock mounts.i've been running this setup for 3 months now,no problems. this means u dont need longer shocks.this can be an upgrade later.factor this in, and the whole system is very reasonably priced. also, in the process of building a bigger lift ,spacing the front subframe a bit. a work in progress. we are getting a lot of positive feedback, so we'll probably have to build some more.
irish_delica83
Vehicle: 92 delica exceed
Post by irish_delica83 »
ya dude im in. 400 bucks i want one at the end of the month 4" front 3" in rear or 2" . do i need new leaf springs maybe add a leaf and shocks can be done after great. I need new wheels and tires
gonna go get muudy after fresh wax
sasquatch-hunter
Vehicle: 2 Delica
Post by sasquatch-hunter »
Saw garyo's van @ North Van Red Robin parking lot. Sweet! Nice lift, and I should consider that as well.
thelazybrownfox
Post by thelazybrownfox »
Hey Garyo
Oh, that does look good!! What is the height at the top of the wheel wells?
Thelazybrownfox
Thelazybrownfox,
I saw VSM's Delica couple days ago with that lift installed. I'd guess a good 6-7" between tire and wheel arch. Nice set up as it doesn't "stretch" the shocks and keeps the geometry the way it should be. I really liked it.
thelazybrownfox
Hey guys
Yes I like the 6-7" tire clearance.
I have 30" BFGs & 32 1/2" height at the top of my wheel wells. Thats only 4 1/2" tire clearance with my torsion bars cranked to an inch of their maximum. They were cranked in Japan before i bought the deli. There's no lift in the rear.
I want a 2" more ground clearance. I suspect the TBs have sagged.
My questions are:
Can you buy new torsion bars? How much are they? Would there be any advantage to replacing the torsion bars rather than installing a lift kit?
Anyone seen a part number for the TBs.
thanks
Thelazybrownfox
garyo
Vehicle: 91 exceed
Post by garyo »
37'' wheelwell to ground w/ completly bald 31's
delica 304
just keeping the thread alive, especially after seeing the install in Houston (ca't remember your name off had, sorry)
