L400 Transmission Mounts
WhoGotTheFunk
Vehicle: Hopefully a Delica
Post by WhoGotTheFunk »
Anyone have part numbers for these mounts?
First pic: No.4 insulator
Second pic: No. 2 on the 4WD side. The 2 insulators
No. 4 insulator
No. 4 insulator
Screen Shot 2013-07-04 at 1.04.30 PM.png (81.54 KiB) Viewed 4262 times
Screen Shot 2013-07-04 at 1.03.23 PM.png (64.8 KiB) Viewed 4262 times
macro
Vehicle: L400 "The Invader"
Re: L400 Transmission Mounts
Post by macro »
I just did mine, huge difference after. Let me know if you find these domestic!
L400 rear transmission mount - MG27M2168
WhoGotTheFunk
Thanks. Are all three the same part number? Where did you get them?
macro
Post by macro »
There's only two, easy to replace with a bottle jack. I got them from Rocky Mountain Imports
Firesong
Post by Firesong »
What were the symptoms your were experiencing to want you to change them?
WhoGotTheFunk
They're just cracked and there's a fair amount of movement. I just got the Delica and would rather just replace them. Super simple to do I figured why not. Hope they're not to expensive.
macro
Post by macro »
Firesong wrote:What were the symptoms your were experiencing to want you to change them?
I had a pretty hefty vibration when idling and taking off from a start. I could really feel it in the 4x4 shifter. U-joints seemed fine, so did pinion. Trans mounts however looked horrible. I was just looking at the front diff mounts though, they also need replacing, and are a much much more involved job I think.
macro
Post by macro »
WhoGotTheFunk wrote:They're just cracked and there's a fair amount of movement. I just got the Delica and would rather just replace them. Super simple to do I figured why not. Hope they're not to expensive.
They're expensive!
Firesong
Post by Firesong »
How much is a mount worth?
macro
Post by macro »
Firesong wrote:How much is a mount worth?
If I remember correctly they're about $125 each. No aftermarket options available and L400 specific. Same with the rest of the motor mounts and bushings.
WhoGotTheFunk
That's crazy expensive. There must be something similar to these for another vehicle. I'll do some digging next week. I may even be able to make something. I mean there's really nothing special about the bracket they mount too.
macro
Post by macro »
WhoGotTheFunk wrote:Thanks. Are all three the same part number? Where did you get them?
Sorry, I didn't read your first post properly. I didn't even know there was a third one! Anyways, keep us posted!
WhoGotTheFunk
Haven't looked into it yet. I will keep you guys posted when I get around to it.
Return to “L400 Technical”
