Centrifuges: Raw Power vs Absolute?
whatthejeez
Vehicle: '96 Delica Jasper
Post by whatthejeez »
Hi folks. I'm looking at these two machines and would love to hear from anyone who owns one. They're a couple hundred (edit: dollars) apart (both equipped with a VFD to increase speed). The Absolute claims a digital controller and superior heating element, while the Raw has a special cone to boost cleaning.
I appreciate any input. This is a substantial investment, and I'd like to make the right choice.
Thanks.
Jordan
Vehicle: 89 low roof L300
Re: Centrifuges: Raw Power vs Absolute?
Post by Jordan »
I recommend Simple Centrifuge, In my opinion you don't want to operate the machine at lower speeds and when you spin your oil while cold it removes solidified fat particles that could be missed when heating. Simple centrifuge has completely redesigned their bowl to eliminate contamination due to oil splashing when being introduced into the bowl while WVO designs has added an afterthought 'feed cone' to address the problem and it looks like Absolute has ignored the problem completely. I haven't tried other brands but I have zero complaints going into my 3rd year with my simple centrifuge.
after oil
Post by after oil »
i got raw power without the cone and it works great. they go on sale once in a while
whatthejeez
Jordan wrote:I recommend Simple Centrifuge, In my opinion you don't want to operate the machine at lower speeds and when you spin your oil while cold it removes solidified fat particles that could be missed when heating. Simple centrifuge has completely redesigned their bowl to eliminate contamination due to oil splashing when being introduced into the bowl while WVO designs has added an afterthought 'feed cone' to address the problem and it looks like Absolute has ignored the problem completely. I haven't tried other brands but I have zero complaints going into my 3rd year with my simple centrifuge.
Thanks for the reply,
That's interesting...so you don't use a pre-heater to spin your oil? Can you finish your oil in one pass, and if so...what kind of rate do you get?
The VFD actually increases the rpm for better flow rate from what I gather.
Jordan
Post by Jordan »
No heat, my setup can do multiple passes but one seems to be fine. I set it up and leave it overnight, I clean 40 gallons in 8-10ish hours. I was using a ball valve to regulate flow that would get clogged sometimes so I recently changed to a gate valve but haven't had a chance to test it to see if it works better.
I think the rotor is the most important component, on Simple Centrifuge the feed cone eliminates cross contamination and the larger bowl holds more oil. If you want more rpm I recommend getting a larger motor but still using the simple centrifuge bowl.
whatthejeez
The VFD option spools these things up over 5000 rpm, so speed isn't a concern.
You mentioned solidified fats getting missed with pre-heated oil...does this mean that under heat the fats will pass through with the clean oil?
I understand that tallow and fat isn't good for the engine...?
Jordan
Post by Jordan »
whatthejeez wrote:The VFD option spools these things up over 5000 rpm, so speed isn't a concern.
I have no experience with them but I think a VFD needs to be paired with a motor capable of those speeds, so you would still be upgrading the motor. In my opinion speed is irrelevant if your bowl is contaminating your oil.
If you process cold oil you're more likely to get the fats that are solidified vs. if you heat the oil and they can pass through easier. I get more gunk in my centrifuge rotor when I clean oil in the winter vs. summer.
dfnder
Vehicle: '91 Exceed
Post by dfnder »
I have a RAW power centrifuge and I am happy with it, I did notice I was getting some splashing so I came
centrifuge fix.JPG (21.18 KiB) Viewed 12924 times
up with an easy fix after looking at their upgrade. Attached see a simple drawing of the RAW Power bowl, I added a small plastic tube onto the small nipple which delivers the oil. This forces the oil to the bottom of the bowl and in my mind greatly improves the efficiency of the centrifuge without the expensive upgrade.
after oil
Post by after oil »
dfnder wrote:I have a RAW power centrifuge and I am happy with it, I did notice I was getting some splashing so I came
8-) 8-) 8-) 8-) 8-)
whatthejeez
Groovy. So now I need to decide if I want to 'fuge the oil hot to get rid of water...or run it cold to remove the solidified fat.
I guess I could run it thru twice...once hot and once cold...
profister told me of a friend's uplift pump becoming clogged with fat not long after his veg conversion. This information would seem to negate the argument that solidified fats will melt in the vegetherm before injection...
Can anyone tell me if the solidified fat is natually occurring in canola oil or from meat being cooked in it...?
dfnder
Vehicle: '91 Exceed
Post by dfnder »
Water is heavier than oil so that is sort of why you let it settle in the cubes, also chunkies usually fall to the bottom as well :)
after oil
Post by after oil »
whatthejeez wrote:Can anyone tell me if the solidified fat is natually occurring in canola oil or from meat being cooked in it...?
i have observed that to be true.
whatthejeez
Which one have you observed to be true?
naturally occurring?
or the result of meat being cooked in it?
after oil
Post by after oil »
ah yes, that was unclear sorry,
Im not a scientist, but i think that the solidified fat you find in canola is animal fat, often from the grill. ask your source to keep the grill fat and wash water separate
BCDelica
Vehicle: WVO Powered Tuk Tuk
Post by BCDelica »
More from the experience of as a restaurant owner, than as a chemist, cooking adds plenty of animal fats to the deep fryer oil.
Unheated delivery of animal fats, and thin fuel lines, can clog before the veggietherm. For the those running there vehicles on pure lard, a heated tank or pickup, is a must. No heated lines, or heating in the WVO tank, your Deli better be full vegan...
Image Call me BCDelica-less
Return to “WVO and Biodiesel”
