Want you Deli to look like this?
I have contacted Metal Monkeys in the UK regarding their lift kit for Delica L300's. They are just finishing up the kit for production. It will give a 3 inch lift over standard. The kit includes the following:
4 x ProComp ES9000 shock absorbers (to match the lift)
4 x matching coloured shock boots
4 x Uprated Polybushes for the shock mountings
2 x longer front brake pipes
1 x rear brake pipe drop bracket in stainless steel
2 x new extended engine mounts
8 x aluminium chassis lift blocks
4 x aluminium rear subframe lift blocks
4 x aluminium transmission spacers
2 x steel radiator relocation blocks
2 x extended rear shackles
2 x rear axle lift blocks
4 x extended rear axle U-bolts
1 x extended steering arm
2 x steel heavy duty front ball joint spacers (matched to the chassis blocks)
A whole host of nuts, bolts and washers matched to each part of the lift.
He is currently coming up for a price without the shocks (to reduce shipping weight) and a shipping cost for me.
This is not a simple kit for the average do it yourselfer, some alterations and fitting is required, but he is providing instructions that a competent of road shop should be able to follow.
If anyone is inerested, please let me know. If we can get 5 or 10 people interested, we can order at once and save some money on shipping and a group discount perhaps.
James
jspyker@this1.ca
Call me BCDelica-less
