Any suggestion as to where I could pick up a compatible plug in harness on the Island?
EDIT: Oooopppps, guess I should have searched more before posting:
EDIT2: Even better. I have an after market tape deck already installed, so I already have a wire harness, just needed a box of bullet connectors. Everyday is a learning experienceLeafster wrote:There's no need to improvise, you can buy a Mitsubishi harness at nearly any car audio shop. Ask for Metra 70-1743 harness for Dodge/Chrysler/Plymouth/Mits imports 1987-1984. Wire it up to the colour matched wires on your aftermarket deck and it's done. You will also have to drill new holes in the mounting bracket and buy a DIN universal pocket to mount below the deck.
