Brand new Wood Steering wheel with adaptor $300 L300 or L400
MardyDelica
Post by MardyDelica »
Hi,
have 1 available brand new wood steering wheel with hub adaptor for your L300 or L400 Direct fit;
makes your orig delica steering wheel upgraded to wood steering wheel
price : $300
pls call me if need this;
Cheers;
604-720-6144
wood steering wheel.jpg (114.09 KiB) Viewed 1848 times
nxski
Re: Brand new Wood Steering wheel with adaptor $300 L300 or L400
Post by nxski »
What regulations are there in BC for having a horn in the vehicle? Does this have one and if not does that matter?
nxski wrote:What regulations are there in BC for having a horn in the vehicle? Does this have one and if not does that matter?
In BC you must have a working horn at hand. How it works was not specified the last time I looked.
Also in BC: A cyclist's bicycle must be equipped with a working bell ~ so for instance if you see a big diesel locomotive baring down on you and clearly not seeing you ~ you can just go "ching-ching" and ward off any impending danger, theoretically. As a cycle courier we generally attracted the attention of the law by our mere presence, I think it could have been our lycra cycling shorts. Typically they would fine one for not having the bell when they were bored and fancied a little sport. We were game. We all purchased a mickey mouse bicycle bell and mounted it on the bicycle, by the sprocket bracket just above the rear axle. When they started propounding from the Motor Vehicle Highway Code we would just point. One time I got nicked because, although I had an air horn, I didn't have a bell.
