Delica L400--needing Alternator?
batfa1
- Vehicle: delica
I just imported a Delica L400, but I have needed to change the battery because when I am driving it. It will suddenly stop and the battery is dead, and then I have to jump start for it to run again. Does anyone know if it is a bad alternator or maybe if it is a massive electrionic drain from some where else in the system?
- MardyDelica
Re: Delica L400--needing Alternator?
hi, maybe its the alternator:
check the gauge in the center dash pod;
right on top of the stereo. you can see if working if not your alternator is no good.
many of this L400 was mistakenly boost in the port wrongfulway when the car is setting in the port.
they wont tell you this. the result is the alternator will be toast;
it cost around $190 for a rebuild one exchange
hope this help
Cheers;
hope this help
Cheers;
