Oil Changed with New Filter
Fuel Filter Replaced
Air Filter Replaced
Rear Diff Fluid Replaced
Front Diff Fluid Replaced
Transfer Case Fluid Replaced
Gear Oil Replaced
Coolant Flushed 2 times.
Sway Bar Bushing Replaced
Brake Pad front & Rear 80%
Front Rotor & Rear Drum Machined.
All Suspension parts regreased
Front hub repacked with new grease.
Fully Detailed inside out.
Roof Rack and Light Bar with 2 Fog Lamp Installed on Roof.
Timing Belt & Balancer Belt are being checked (if any crack found, we will replace Timing Belt, Balancer Belt, Both Tensioners, Crank and Cam Seal & Waterpump with no extra cost)
Photo Showing old tires.
Immaculate condition both in and out. Absolutely no accident and no rust! Fully serviced and inspected with 4 brand new tires. Price $10,600. Comes with 1 year warranty
