4wd indicator switch/sensor
- torchard
- Vehicle: 91 Exceed
Granted, I haven't gone under and looked for myself so this may be obvious, but I determined that the instrument panel mounted 4WD indicator bulb is NOT blown out, so I'm thinking it's not getting any current because ...?  Is the switch/sensor at the transfer case?  How does it work?  Has anyone else experienced a non-functional 4wd indicator which was not a burnt bulb?
BTW it does shift into 4wd, so I figure it's with the switch rather than some larger mechanical issue.
'91 Exceed
Nimbus 2000
						Nimbus 2000
Re: 4wd indicator switch/sensor
there was a post recently on the UK site about this, apparently the wire as it comes off the transfer case is pretty brittle and may have broken... check there... (one of these days I'll sort mine out too, for now I just use the "wheel lock" light as my indicator...)
						- torchard
Hi Brett,
So there's two lights? One which indicates the van is in 4WD and another, the wheel lock indicate, which tells you the hubs are engaged? If that's the case, neither of mine work. I know where the wheel lock light is but not the other...?
I was orginially referring to the wheel lock light as that was the only one I was aware of. I did stick my head under and the wires at the transfer case do look a little fragile.
--T
--T
Green1 wrote:there was a post recently on the UK site about this, apparently the wire as it comes off the transfer case is pretty brittle and may have broken... check there... (one of these days I'll sort mine out too, for now I just use the "wheel lock" light as my indicator...)
				Adam
Hmmm, what does the wheel lock light look like? I see my 4WD light which goes on and off between 2H & 4H shifting once the hubs are locked. I just have to stop the first time I shift into 4H to lock the hubs, but I don't have an indicator light once I shift back to 2H even though the hubs are still locked.torchard wrote:So there's two lights? One which indicates the van is in 4WD and another, the wheel lock indicate, which tells you the hubs are engaged? If that's the case, neither of mine work. I know where the wheel lock light is but not the other...? I was originally referring to the wheel lock light as that was the only one I was aware of. I did stick my head under and the wires at the transfer case do look a little fragile.
				docsavage
- Vehicle: Deliless...
The 4wd light has a sender at the back of the transfer case.  A bundle of wires is hanging back there, the yellow one with small red checks is for the 4wd light.  Mine broke once, and as you can see in the picture is Broken again.
Fix and wrap it up and it should be alright (I didn't wrap mine again, oops)
James
James
James
1989 Delica P24W Exceed
Panasonic CQ-TX5500W
- torchard
Excellent - thanks. Looks similar to the mess I saw last night. Thanks for confirming the yellow wire.
--T
						--T
docsavage wrote:The 4wd light has a sender at the back of the transfer case. A bundle of wires is hanging back there, the yellow one with small red checks is for the 4wd light. Mine broke once, and as you can see in the picture is Broken again.
James
- torchard
The wheel lock light glows green when it works and can be found on the bottom of the instrument panel in line with the glow plug, oil pressure, etc indicator lights. Apparently it stays lit as long as the hubs are engaged. Squint and you'll see it even it doesn't illuminate. If there is a light to indicate that the transfer case is engaged, I dunno where it is.
						Adam wrote: Hmmm, what does the wheel lock light look like? I see my 4WD light which goes on and off between 2H & 4H shifting once the hubs are locked. I just have to stop the first time I shift into 4H to lock the hubs, but I don't have an indicator light once I shift back to 2H even though the hubs are still locked.
				Adam
Found it
OK, I see the Wheel Lock light.  Mine doesn't illuminate when the hubs are locked (red circle), but the 4WD light does (orange circle).
- torchard
Re: Found it
So I got under there and unwrapped the bundle and repaired two wires (yellow and black I think) connecting to two red leads via bullet connectors running to the back of the transfer case. This repair got the 4wd light to illuminate (circled orange in above photo). I chased the yellow line back a bit but didn't find anything broken or particularly weak in appearance. So half the battle is won, which might be enough to calm me for a while.
Anyway I reverse frequently enough so it's not as if I"m going to be driving around for any length of time with the hubs locked.
--T
[quote="Adam"]OK, I see the Wheel Lock light. Mine doesn't illuminate when the hubs are locked (red circle), but the 4WD light does (orange circle).
--T
- DelicaMark
- Vehicle: L400
I had the same problem with both 4WD and Wheel Lock lights.  I fixed the 4WD drive light but the yellow wire for me was still intact.  When I was checking out which wire I fixed the 4WD light came on and stayed on and the wheel lock light came on then went out.  Assuming that there is something loose with that other wire...will have to keep searching or not bother.  I can here the hubs unlock when I reverse...good enough maybe?
BTW thanks for the posts, it made it pretty easy and quick to figure out.
-Mark
-Mark
- DelicaMark
- Vehicle: L400
One thing I have noticed with this.  By fixing the one yellow wire I got both the 4WD and Wheel Lock lights to come on.  This makes me think that if only one of your lights are coming on then you likely have a burnt out light because it seems like they are linked in some way.  Could be wrong just as easily...just a thought.
				coaxial
wierd on a 5spd manual the wheel lock is a little higher and the other light is right under it.  I have the green wheel lock light working but the other does not. I will crawl under tonight and check out the wires.
I wish that either monsoon season would end or that I had a garage
				coaxial
this shows the wiring of the sensors it seems
http://iis.neverhost.net/delica/L300-delica%20trans.pdf
				coaxial
well I was underneath for a while tonight and still only a wheel lock light, no 4wd light. I've got a 92 exceed but it's quite a different scene around my transfer case, no big bundle of wires but a bunch of neatly wrapped ones tucked away. I spotted one red wire that was worn and almost broken and repaired that, couldn't find a yellow wire or anything else broken.
Any tips to find the yellow wire? where on the case does it come out of?
- 39Ronin
coaxial wrote: Any tips to find the yellow wire? where on the case does it come out of?
My yellow wire was black, but after I cleaned it was yellow again. Have another look and try to clean of the wires and maybe you will see it.
