Most Reliable Model?
Hello all! I am on my way to Africa and trying to find out which of the Delica models would be considered most reliable for the harsh African road conditions? Any suggestions?
Re: Most Reliable Model?
Nissan Patrol or Landcruiser 7x series. Those are the two vehicles of choice for reliability/dependability in Africa.
It's the drivetrain/suspension that is tested there, more so than the engine (most diesels are good), although if you're set on Delica's, both have their positives.
L300 frame is more stout / smaller footprint / more room inside
L400 drivetrain and engine is more stout/reliable/suited to be pushed hard
Many thanks for the info!
-Just what I needed to hear
- sasquatch-hunter
- Vehicle: 2 Delica
If a Celica can make it through, any Delica can make it.
Sure. If you can put in 20 grand in dakar modifications and a support crew to help you.
I have an admiration for those drivers, but their rigs and support are not typical of the average person.
Albeit, there are the older-style L300's cruising around there.
If I were to venture across Africa, I would use what the people there use in the middle of the desert. Patrols and troopy's.
You can run those 4.2L NA diesels into the ground, literally, and they will keep on running. There is no engine that is mass produced that is as reliable and bulletproof as the Nissan TD42 and the Toyo 1HZ. Mining trucks, military and NATO put millions of miles on single engines.
- snelson
- Vehicle: 92 Delica Exceed
Oh come on - everyone knows the best vehicle for the job is a '63 Opel Cadet!
- Vehicle: Subaru Sambar SC
if you do decide to go with a troopy then i have a line a beautiful 1995 unit, not cheap but VERY clean.
cheers
cheers
http://www.luxuryimports.ca JDM imports
that was enjoyable, love that show.
thanks for posting, i had not seen this one.
snelson wrote:Oh come on - everyone knows the best vehicle for the job is a '63 Opel Cadet!
