94 Delica L400 SPACEGEAR T-Diesel 5 Spd Arrived * SOLD*
MardyDelica
Post by MardyDelica »
1995 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, 4x4, exceed model, 114,000 kms on it.
Rare 5 Speed ManualTransmission, A/C, short wheelbase, Nice very rare to find Nice clean low mileage 5 Speed L400.
its A grade 4 which is good.
This Delica L400 comes with the full service on it when you purchase.no need to bring this L400 to any shop to service it which cost you very expensive for repair.
in Short we totally almost do necessary thing need to be change for this Vehicle. will come out almost like brand new car.
8 original seat belt for 8 passenger no modification for additional 8 seat, 134A AC, fully loaded, will do full compliance, Original Mitsubishi E-code headlight for Left hand drive.
brand new radiator,water pump, thermosthat, Fluids, new tire,new shocks which is a must to change any L400 coming from japan most of this L400 shock is not good, will install pro comp 9000 series shock front & rear, will replace water bootle if any sign of crack, also will replace hose if seen any sign of wear & tear and full service for this newly designed L400 Delica.
will install block heater,all fluids will be replace & lube.
injection pump seal replace, check & replace glow plug if glow plug is no good.
do the proper timing adjust the TPS sensor on it to make your L400 runs smooth like a car.
replace water bottle(Anti freeze) as this is a common problem with L400
this is a fully service L400 which make this L400 last longer when its been service.
As you can see no rust under & thru the front chassis. nice shape;
It comes with a full B.C. prov. compliance & inspected vehicle registered here in B.C.. nothing to do just insured it when you buy this L400.
will do everything for you.
this comes with 1 yr or 12,000 kms power train warranty whichever comes first, despite of the full service we do for this L400.
Stock# PD8W=5 spd Green
SOLD
Please call me anytime,
604-247-2111/ 604-720-6144
Cheers;
MardyDelica
Re: 94 Delica L400 SPACEGEAR T-Diesel 114k 5 Spd *SOLD*
More Pictures;
MardyDelica
Re: 94 Delica L400 SPACEGEAR T-Diesel 5 Spd in Transit
Hi, its on sale now
will be here next month
rare nice 5 Spd L400 low roof good for underground parking
for inquiry pls call me anytime
Cheers;
MardyDelica
Re: 94 Delica L400 SPACEGEAR T-Diesel 5 Spd Arrived on HOLD
Hi, This Delica L400 Arrived
its on HOLD now
Thank you very much,
MardyDelica
Re: 94 Delica L400 SPACEGEAR T-Diesel 5 Spd Arrived * SOLD*
Hi, this delica L400 Is SOLD
thank you very much
Cheers;
