BRAND NEW 4D56 ENGINE IS AVAILABLE NOW.
mdrive
Post by mdrive »
WE HAVE ONE BRAND NEW ENGINE FOR DELICA AVAILABLE. IT IS A COMPLETE BOLT ON ENGINE. YOU DON'T HAVE TO DO ANYTHING. You can buy the core engine or complete with Turbo, Alternator, Fuel pump, Fan Clutch, etc Please call for pricing.
L300Foca
Vehicle: Mitshubishi L300 2.5 TD GLX
Re: BRAND NEW 4D56 ENGINE IS AVAILABLE NOW.
Post by L300Foca »
mdrive wrote:WE HAVE ONE BRAND NEW ENGINE FOR DELICA AVAILABLE. IT IS A COMPLETE BOLT ON ENGINE. YOU DON'T HAVE TO DO ANYTHING. You can buy the core engine or complete with Turbo, Alternator, Fuel pump, Fan Clutch, etc Please call for pricing.
How much Euros? :)
FollowMe
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
1.00 CAD = 0.723814 EUR
rightnwrong
Vehicle: Mitsubishi Delica
Post by rightnwrong »
It sounds interesting but I want to make sure. I want to see them first. Post some photos please. Thanks.
Jester
Vehicle: Delica
Post by Jester »
:-D lol
Here is one installed not long ago.
mdrive
Post by mdrive »
Thanks Jfarsang for posting the installed eninge. Here is the photo.
deli1733
Vehicle: 1991 L-300 94 Pajero LWB
Post by deli1733 »
Where are these engines made? I heard that the engines from china are using cheaper and softer metal for the heads.
lrp374
Vehicle: 91 Super Exceed
Post by lrp374 »
Sure would be easy to put a block heater in that one!!
What model is that engine? It looks similar to a 4D56... Who makes it?
mdrive
Post by mdrive »
This is made by Hyndai under the license from Mitsubsihi Motors. They are not cheaply built, it has been in prpduction for almost 10 years and still used in new vehicles manufactured by Hyundai.
Some questions....
  • Is it a 2.5L?
  • I see it has a VI IP, how does it differ from the VI IP on the 4D56? (solenoid power feed, tuning screw, &c.)
  • The timing belt appears to take a different path, how different are the timing belt layouts to the 4D56?
  • What kind of alternator is that?
  • I see that drive belt #3 appears to have teeth, do these match up with teeth on the pulleys?
  • What about the A/C and P/S pulleys, do they have teeth?
  • Would one need to replace the corresponding pulleys on the A/C & P/S pumps?
  • How else does it differ from the 4D56? What is the general HP?
  • How close does the dip stick get to the engine compartment bulkhead?
Cheers, Sabir.
mdrive
Post by mdrive »
FalcoColumbarius wrote:Some questions....
  • Is it a 2.5L? It is 2.5 Turbo 4D56 Engine
  • I see it has a VI IP, how does it differ from the VI IP on the 4D56? (solenoid power feed, tuning screw, &c.) Same IP but motor is manual transmission so the kick down cable needs to remount from the old IP
  • The timing belt appears to take a different path, how different are the timing belt layouts to the 4D56? Same T Belt.
  • What kind of alternator is that? the alternator is same excpts the Japanese 4d56 alterator has female jack and thsi one has male jack. We are adding converting the jack before installation.
  • I see that drive belt #3 appears to have teeth, do these match up with teeth on the pulleys? Pulleys are same, you can use smooth or teeth type belts, both.
  • What about the A/C and P/S pulleys, do they have teeth? Does not come with PS or AC, so the old pulleys needs to be swapped.
  • Would one need to replace the corresponding pulleys on the A/C & P/S pumps? SWAP
  • How else does it differ from the 4D56? What is the general HP? same HP.
  • How close does the dip stick get to the engine compartment bulkhead? same as your delica. No difference.
Cheers, Sabir.
cdalejef
Vehicle: B2600i with 4D56
Post by cdalejef »
I just ordered one of these from them, can't wait till it gets here. :-)
Jester
Vehicle: Delica
Post by Jester »
cdalejef wrote:I just ordered one of these from them, can't wait till it gets here. :-)
how much did it run ya?
