HEY everyone,
I had a bit of a fender bender recently because my brakes failed (rubber for the brake hoses was old/cracked).  Anywho, I am now searching for a replacement passenger side mirror, and the glass for the left headlight was broken.  The light still works,  so i'm not sure if I need to replace the whole assembly or just the glass?   If anyone has any of these parts laying around or knows of a reasonable replacement option for the mirror, I'd be grateful.  Thanks in advance.
P.S. the lower arm for the passenger mirror was completely bent onto itself.  If I am able to unbend it without it breaking, I may just need the mirror itself.
						NEEDED: Passenger side MIrror & Passenger headlight glass
Moderators: delicanuck, mark
- snelson
- Vehicle: 92 Delica Exceed
Re: NEEDED: Passenger side MIrror & Passenger headlight glass
Hey just FYI the actual mirror & casing is the same on both sides for the L300 - so if you find a driver side mirror, you could use that on the passenger side.
				GWr
- Vehicle: 1991 Mitsubishi Delica Super Exceed
Thanks for the info!!  I took apart both the passenger & driver's side mirrors, and was able to swap out parts from each to make a "new" passenger side mirror.  That will help until I can source another.  The passenger side mirror seemed essential when driving and changing lanes, so your tip was really helpful.  Thanks for sharing.
						- snelson
- dennis_lambert
Hi there,I have some brand new replacment mirror Assy arriving sometime next week,Do you still need some?
Dennis.
Dennis.
- Artacoma
- Vehicle: 97 V6 LWB
