Starter wiring
nismo.farlady
Starter wiring
Can anyone please tell me which wires go where? I have a 1991 Pajero 2.5L and I replaced my starter and when I bought my starter there is a wire attached to the starter looks like its sawdered, then the two wires in the truck its self one going to the positive terminal of the battery and the other one going I dont know where. Does the wire from the positive battery terminal attach to the connection on the starter that is closest to the block, or the connection that is farther away from the block. Thanks.
- Luna-Sea
Re: Starter wiring
Did you get this one figured yet?
I can go crawl under mine and take a pic if you are
still up the poo-creek.
Right On!
Right On!
Re: Starter wiring
Is the starter different in a Pajero as in a Delica? They both use the same engine. Have you looked in L300 Delica Downloads for the 4D56T Engine Manual?
P.S.: Nismo, what area are you located? Your profile doesn't say.
