Looking to build my own exhaust
I need the section of exhaust from the manifold back to the first joint. Anybody that changed to the side dump chromies got one laying around ?
Gregg
Exhaust Section Needed
Moderators: delicanuck, mark
- Golf Cart
- Vehicle: 1992 Exceed
Re: Exhaust Section Needed
Do you mean the exhaust adapter or the first leg of stock exhaust? If you look at the system diagram, the manifold is upstream from a bunch of stuff and the adapter is the offset that takes the output down to the exhaust. The spring loaded fasteners are where the exhaust starts. After that part, exhaust parts abound. I know there is one at the Tardis planet, and I think Delicat is the one to talk to about it. I'll have bits in a few weeks...
Richard Dagenais
- Golf Cart
first leg of the stock exhaust.
Yup, PM Delicat about the one at TardisDeli's place. Last I heard it was a complete (working) exhaust, I believe it was donated to RHD legal.
Richard Dagenais
gtexjunkie
- Vehicle: 92 Delica GLX (P25W) 5spd
Golf Cart,
If you looking for a flange then go to muffler tech the have some nice SS ones and the could even weld you on your first joint. The flange I think was $33 ish. Look here in the Dino build up for photos http://dinoevo.de
If you looking for a complete exhaust then there is one at TardisDeli's. It is stock and in very good shape. When I swapped over to a SS side dump it no longer needed it, did not want to take it back to Cowtown, maybe there was someone in need, donate to the RHD legal battle.
I would rather the system go complete to the highest bidder for the RHD cause than chopped up for parts. Either Delicat or Tardis Deli are the ones to contact.
Jason
Jason
