1995 L400 Delica Spacegear T-Diesel Low Roof 82k * SOLD *
MardyDelica
Post by MardyDelica »
1995 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, 4x4, exceed model, 82,000 kms on it.
Automatic, A/C, short wheelbase, Nice very rare to find Nice clean low mileage white color L400.
its does have a middle monroof & front sunroof on it.
This Delica L400 comes with the full service on it when you purchase.no need to bring this L400 to any shop to service it which cost you very expensive for repair.
in Short we totally almost do necessary thing need to be change for this Vehicle. will come out almost like brand new car.
8 original seat belt for 8 passenger no modification for additional 8 seat, 134A AC, fully loaded, will do full compliance, Original Mitsubishi E-code headlight for Left hand drive, double battery for winter package .
brand new radiator,water pump, thermosthat, Fluids, new tire,new shocks which is a must to change any L400 coming from japan most of this L400 shock is not good, will install pro comp 9000 series shock front & rear, will replace water bootle if any sign of crack, also will replace hose if seen any sign of wear & tear and full service for this newly designed L400 Delica.
As you can see no rust under & thru the front chassis. nice shape;
It comes with a full B.C. prov. compliance & inspected vehicle registered here in B.C.. nothing to do just insured it when you buy this L400.
will do everything for you.
this comes with 1 yr or 12,000 kms power train warranty whichever comes first, despite of the full service we do for this L400.
Stock# PD8W=White
ON HOLD
Please call me anytime,
604-247-2111/ 604-720-6144
Cheers;
white low roof 82k.jpg (53.32 KiB) Viewed 2745 times
white low roof 82k 2.jpg (49.76 KiB) Viewed 2744 times
White low roof 5.jpg (52.72 KiB) Viewed 2746 times
white low roof 3.jpg (36.67 KiB) Viewed 2745 times
white low roof 4.jpg (60.53 KiB) Viewed 2742 times
white low roof 82k 1.jpg (64.75 KiB) Viewed 2742 times
MardyDelica
Re: 1995 L400 Delica Spacegear T-Diesel Low Roof 82k * On HOLD *
Hi, This L400 is on HOLD
Thank you very much
MardyDelica
hi, this delica arrived
Cheers;
MardyDelica
Re: 1995 L400 Delica Spacegear T-Diesel Low Roof 82k * SOLD *
HI, This Delica L400 Is SOLD
Thank you very much
