1995 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Exceed model, Metallic dark green color with Grey color tone on it, L400, has 104,000 kms.
this car is clean.
Automatic, crystal lite roof, A/C, 7 passenger, 134A AC, fully loaded, will do full compliance
Will install New original Mitsubishi headlight E-Code, and full service for this newly designed L400 Delica
New Tire, Radiator, Water Pump, thermosthat, Belt, air filter, fuel, all fluids change , new 4 shocks pro comp 9000 series
Check all brakes, Delica L400 tune,new coolant, check stabilzer bushing if need change, replace water bottle anti freeze, if broken or seen any sign of cracks. this delica is clean.
will Include a 1 yr or 12,000 kms Powertrain Warrantty whichever come first:
Stock # PE8W-104k
Pls call if any inquiry:
Amazing Auto imports Ltd
604-247-2111 / 604-720-6144
95 Delica L400 SPACEGEAR Diesel 104k Auto * SOLD *
- MardyDelica
- DSCN0841.JPG (85.85 KiB) Viewed 2208 times
- DSCN0842.JPG (88.41 KiB) Viewed 2208 times
- DSCN0845.JPG (86.67 KiB) Viewed 2206 times
- DSCN0847.JPG (89.17 KiB) Viewed 2207 times
- DSCN0848.JPG (70.58 KiB) Viewed 2208 times
- DSCN0851.JPG (81.66 KiB) Viewed 2207 times
- MardyDelica
Re: 95 Delica L400 SPACEGEAR Diesel 104k Auto * On HOLD *
Hi, This Delica L400 Arrived On HOLD for now:
Thank you
Thank you
- MardyDelica
Re: 95 Delica L400 SPACEGEAR Diesel 104k Auto * SOLD *
Hi, this Delica Is SOLD
Thank you very much
Cheers;
Thank you very much
Cheers;
