C.V. Shaft
- Hankster
- Vehicle: 92 P-25 MyPod
C.V. Shaft
Just wondering if there are any "Tricks" when changing a C.V. Shaft. I haven't come across anything in the archives. Any input would be appreciated.
*<I;D MyPod !!
Re: C.V. Shaft
It's not easy.
Drivers side is easier because the inner flange bolts to the diff.
When I do them, the spindle knuckle and hub assembly has to come off.
You can't remove the CV axle without removing the upper balljoint and tierod. You may have to remove the lower balljoint as well.
Have a massive hammer available and be prepared to have to replace the balljoints and tierods if they are no good.
Usually takes me a few hours per side.
- Hankster
Re: C.V. Shaft
I like doing all the mechanical work on my rigs, but this one is nice if someone can do it.  It's a pain.
- ianmair
- Vehicle: '92 Delica L300
Re: C.V. Shaft
Hi guys, just spotted your thread here.
Check out this guide on MDOCUK, should have what you're after. I've done the job myself and a couple of bits were much easier with this guide!
Ian
Ian
92 L300 Exceed & 93 Jasper based in Cambridge, UK
(ex) 88 Delica L300 based in Methven, New Zealand
(ex) 91 L300 Panel Van based in Cambridge, UK
I update My Photobucket Gallery when I do work on the van - feel free to use the images in your posts!
- Hankster
