Hey so I had my heating fan (defrost) stay on after i turned the ignition off one day.. thought that was wierd. went away the next day. now after driving all night to tofino i had the lights stay on and not turn off after turning off the van. had to pull the battery connection off to get em off. when i put it back on the next morning it was fine.
do i have a ghost in the deli? anyone seen this before?
Mitch
electrical weirdness
mitch
Re: electrical weirdness
how are your daytime running lights wired? the wiring my importer did for DRL on my van was a wire between the accessory position on the ignition and the lights, so if you left the lights on the fan would stay on, and I can easily see some form of a situation where things would cause issues the other direction too... (I've since changed my DRL setup to operate on a relay)
