HELP!! RAN OUT OF DIESEL!!!
So i found out the hard way that my empty light no longer works. My van is now sitting in a parking lot and i need to fix it.
WHAT DO I HAVE TO DO TO PRIME THE FUEL SYSTEM??
Im going to try and put some more diesel in it but I dont think it will start
- dennis_lambert
Re: HELP!! RAN OUT OF DIESEL!!!
I would try removing the battery for saftey then remove bleed bolt on top of fuel filter assy.On top of the fuel filter assy is a pump.pump it until fuel starts coming out of hole.Put bolt back in and start.You might have to do this several times to get all the air out.
Hope it helps.
Hope it helps.
Not sure on the Mitsu if it helps to crack the lines on the injectors or not.
I would also put a new fuel filter in before you start encase it sucked up some stuff from the bottom of the tank. Then prime it as above. If it has doesn't start I may crack the fuel lines at the injectors (helps on tractors, but my Mercedes would start no problem with the prime.
Good luck.
Good luck.
Well i found out the hard way that my empty light no longer works
HOW DO I PRIME THE FUEL SYSTEM??? my van is stuck in a parking lot and i have to fix it!!!
thanks in advance for your help and please spare me the "shouldnt let it get that low anyway" talk. thanks.
how do you pump it?dennis_lambert wrote:I would try removing the battery for saftey then remove bleed bolt on top of fuel filter assy.On top of the fuel filter assy is a pump.pump it until fuel starts coming out of hole.Put bolt back in and start.You might have to do this several times to get all the air out.
Hope it helps.
- Firesong
You don't need to remove the battery.
Why would you do that?
weird.
As stated in the 2.5 4D5 Fuel pump pdf found here in the files
1. Loosen the fuel filter air plug
2. Place rags around the air plug hole. Operate the hand pump repeatedly until
no bubbles come from the plug hole. Tighten air plug.
3. Repeat until the hand pump operation becomes stiff.
Give it a go.
Firesong
weird.
Give it a go.
Firesong
First i want to thank you guys for the quick reply second i am no where near my van right now and i was wondering where the hand pump is? is it obvious? what does it look like?
im about to head down there and i want to make sure i know i can find it before i leave
- Mr. Flibble
I am by no means an expert, but on most Diesels there is a pump on the top of the fuel filter, just a little circular spring thing that you can press down. If I remember correctly, you remove the fuel line to the engine, and press the pump on the top of the fuel filter over and over again until fuel comes out of the line, then you hook the line back up and then pump the pump about 40X more, then try to start it.
BUT - I would not try this based on my opinion alone. I believe that the injection pump can be damaged if this is done incorrectly!
- Jungle Jon
- Vehicle: Toyota Tacoma
It's a disk shaped thingy on the top of the fuel filter assembly, a little more than 1 inch across.
It's visible in the top left corner of this pic: http://www.delica.ca/Photos/albums/user ... MG2439.JPG
- EnviroImports.com
yup, your going to have to pump the top of the fuel filter until it gets Hard , then you will have to pump the throttle pedal as you start it, once you get it started, you will have to back off the nut on each fuel line right at the injector and have it pump out the air, you will need a rag to catch the high presure fuel spray, should take a few seconds per fuel line, got to get the air out...not as tough of a job as its made out to be, just a little intimidating when you havent done it before.
There is a little 10mm bolt on the top/side of the filter housing.
That is the bleed valve.
Pump the pump until it gets hard. Then crack the 10mm bolt open until air/diesel comes out. You'll probably see lots of air.
Repeat that as many times as it takes until just diesel comes out without bubbles.
That will get you drivable.
Then follow Noel's steps by cracking the nut on the injectors to bleed each of them out there.
CHANGE THE FUEL FILTER FIRST!! It will be full of stuff at the bottom of the tank and you risk doing damage to the injector pump $$$$$$$$$$
Good luck
Good luck
crushers
- Vehicle: Subaru Sambar SC
for a cleaner bleed then hand pump till firm, crack the bleeder, lock and repeat till all air is gone.
Firesong wrote: As stated in the 2.5 4D5 Fuel pump pdf found here in the files
Give it a go.
Firesong
http://www.luxuryimports.ca JDM imports
- dennis_lambert
[quote="Firesong"]You don't need to remove the battery.
weird.
Sorry I did not mean "remove Battery" , I mean Disconect Battery..for saftey.The fuel filter assy and Battery are in close proximity.I would personally want to prevent any sort of spark when performing the bleed procedure.
I know I am a little weird.
weird.
crushers
the idea of disconnecting the battery is not a bad one.
also understand it takes a lot to ignite diesel. a spark will not ignite it, a constant "glow" from a shorted out wrench soaked in diesel might be a concern though.
dennis_lambert wrote:Firesong wrote:You don't need to remove the battery.
weird.
