From the Parts Number Guide in the the forum.
Alternator Belt
MD313 660
Dayco 11A 1105
Valve Timing Belt
MD134 377
Dayco 94019 94012
Power Steering Belt
MD 180581
Dayco 13A 0750
- Goodyear 17371
Air Con Belt
MB 272652
Dayco 13A 0935
- Goodyear 17305
From CarQuest in Ontario the Alernator belt part numbers above the belts are too long.
The Air Con Belt CarQuest doesn't have any listing/conversion for any of the belt part numbers listed above.
The Power Steering Belt can be converted at CarQuest and fits.
Could someone update these belt numbers with a NAPA belt part number or something that is listed in all Canadian Parts stores or even maybe the belt sizes in inches might be a help also.
I will update the CarQuest part numbers when I get knew belts.
Thanks.
						L300 Belt Part Numbers
				alovelyman
- Vehicle: 1992 Exceed
Re: L300 Belt Part Numbers
Does anyone know the Power Steering, Alternator and Air-Con Belt numbers for NAPA.
							_____________________________
1992 Delica Exceed (Mostly Stock)
2003 VW Jetta TDI
2003 VW Jetta TDI
- Fishtank
You should be able to take the part #'s above to any parts person at any store and they can cross reference to their numbers.  If they can't, they shouldn't be working there.
				yojimbo
The alty belts I just got were 1090's, and went on ok with a lot of adjustment left.
							1994 L300 Jasper
1986 Scimitar 1.8Ti
						1986 Scimitar 1.8Ti
