Hey guys
Im looking for an L400 sunroof motor. If you, or anyone you know, has one or can get one, please let me know asap.
I can be reached at matt@rightdrive.ca
Thanks guys (and gals),
Matty
L400 Sunroof motor
Moderators: delicanuck, mark
matty
- Vehicle: 1993 Toyota Supra
L400 Sunroof motor
Head of Marketing;
http://www.rightdrive.ca
http://www.rightdriveparts.com
http://www.rightdriveusa.com (Coming Soon)
Right Drive Service Center
- loki
Re: L400 Sunroof motor
matty wrote:Hey guys
Matty
call Mardy at amazing auto imports, Glen at CCAutos or John at Rocky Mountain Imports.
are you sure it's the motor? sometimes you can turn the gear around and that fixes things, other times the screws that hold the motor down are just loose or missing.
aclarker
- Vehicle: L400 Super Exceed
Loki is right. I had a problem with my sunroof. A little bit of loctite on the screws re-tighten you're good to go. A small pain to lower the roof liner to get at the motor and the screws around the motor. When you access the motor check the gear it may of been damaged from use.
