Howdy, I've got a 91 L300 and a shot ball joint. I've done the searches on this site and got some part numbers....unfortunately, I live in williams lake and all the parts suppliers say that those pn don't work ( napa and taylor).....so I ordered a ball joint for a 91 Montero.....not sure if its the same, I've never had it out....could someone post a pic of the proper joint uninstalled so I can compare. The pn of the joint I have is napa 260-1250.
Thanks guys :)
upper ball joint
Helidriver
Re: upper ball joint
Contact CVI Automotive on (604)-247 0500.
L300 and L400 upper/lower balljoint are the same
L300 and L400 upper balljoints are not the same as Montero's (control arm is different)
Montero lower balljoints will fit providing you cap off the grease nipple as it doesn't clear the control arm on L300/L400's
