1995 L400 Delica Spacegear 2.8L intercooler turbo Diesel, 4m40 engine, Auto, 4x4, Super Exceed model, white color, L400, has 127,000 kms with hard to find Flair attached on this Spacegear.
very nice indeed:
Front Crome bullbar, Aluminum front Skid plate. Crome side step & rear bumper.
This is th etop of the line on this model.
Front Sunroof & rear Shades all workin gperfectly.
Automatic, crystal lite roof, A/C, 7 passenger, 134A AC, fully loaded, will do full compliance
Will install New original Mitsubishi headlight E-Code, and full service for this newly designed L400 Delica
New Tire, Radiator, Water Pump, thermosthat, Belt, air filter, fuel, all fluids change , new 4 shocks pro comp 9000 series
Check all brakes, delica L400 tune,new coolant, check stabilizer bushing if need change, replace water bottle anti freeze, if broken or seen any sign of cracks. this delica is clean.
In Transit
Stock # PE8W
Any questions please call me:
thanks,
95 Delica L400 SPACEGEAR T-Diesel 127k Super Exceed * SOLD *
- MardyDelica
- DSCN1090.JPG (85.1 KiB) Viewed 2849 times
- DSCN1092.JPG (83.77 KiB) Viewed 2848 times
- DSCN1096.JPG (84.83 KiB) Viewed 2847 times
- DSCN1097.JPG (73.47 KiB) Viewed 2845 times
- MardyDelica
Re: 95 Delica L400 SPACEGEAR T-Diesel 127k Super Exceed In Japan
More Pictures:
- DSCN1098.JPG (70.77 KiB) Viewed 2830 times
- DSCN1100.JPG (81.03 KiB) Viewed 2833 times
- DSCN1102.JPG (67.55 KiB) Viewed 2828 times
- DSCN1106.JPG (80.41 KiB) Viewed 2818 times
- DSCN1109.JPG (57.21 KiB) Viewed 2820 times
- DSCN1111.JPG (59.12 KiB) Viewed 2817 times
- MardyDelica
More Pictures;
- DSCN1129.JPG (90.4 KiB) Viewed 2799 times
- DSCN1127.JPG (70.1 KiB) Viewed 2795 times
- DSCN1126.JPG (84.83 KiB) Viewed 2793 times
- DSCN1123.JPG (90.9 KiB) Viewed 2789 times
- DSCN1121.JPG (94.23 KiB) Viewed 2781 times
- DSCN1114.JPG (74.53 KiB) Viewed 2776 times
- MardyDelica
Re: 95 Delica L400 SPACEGEAR T-Diesel 127k Super Exceed on HOLD
Hi, this Delica L400 is on HOLD
Thank you
Thank you
- MardyDelica
Re: 95 Delica L400 SPACEGEAR T-Diesel 127k Super Exceed *SOLD*
Hi, this L400 Is SOLD
Thank very much
Thank very much
